Only one wavemaker pump toggles. The second pump on port 6 never turns on. Any ideas?
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, 5, 65, "Temp");
ReefAngel.LCD.DrawText(COLOR_BLUE, COLOR_WHITE, 10, 85, "PH");
char text[7];
ReefAngel.LCD.DrawHugeNumbers(T1TempColor, DefaultBGColor, 28, 60, text);
ReefAngel.LCD.DrawHugeNumbers(PHColor, DefaultBGColor, 28, 80, text);
ReefAngel.LCD.DrawText(0,255,100,65, "CW");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,115,65, ReefAngel.PWM.GetDaylightValue());
ReefAngel.LCD.DrawText(0,255,100,85, "RB");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,115,85, ReefAngel.PWM.GetActinicValue());
ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardFan( Port1,779,781 );
ReefAngel.StandardHeater( Port2,770,775 );
ReefAngel.StandardLights( Port3,1,0,12,0 );
ReefAngel.StandardATO( Port4,60 );
ReefAngel.WavemakerRandom( Port5,180,360 );
ReefAngel.WavemakerRandom( Port6,180,360 );
ReefAngel.Relay.DelayedOn( Port8,2 );
ReefAngel.PWM.SetDaylight( PWMParabola(13,0,0,0,0,50,0) );
ReefAngel.PWM.SetActinic( PWMParabola(12,0,1,0,0,95,0) );
ReefAngel.Timer[LCD_TIMER].Start();
Re: Only one wavemaker pump toggles
go read where Roberto helped me:
http://forum.reefangel.com/viewtopic.php?f=11&t=2520
Let us know if you still need help. Thx
