UV LEDs as moonlights
Posted: Mon May 20, 2013 3:46 pm
by Rodasphoto
How can I program my UV chips to stay on as moonlights after completing a parabolic day cycle?
Re: UV LEDs as moonlights
Posted: Mon May 20, 2013 3:48 pm
Can you post your code?
Posted: Wed May 22, 2013 4:11 am
by Rodasphoto
    ReefAngel.FeedingModePorts = Port5Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
    ReefAngel.StandardLights( Port2,9,0,21,5 );
    ReefAngel.StandardLights( Port3,9,0,21,30 );
    ReefAngel.StandardLights( Port4,9,0,21,30 );
    ReefAngel.WavemakerRandom1( Port5,60,100 );
    ReefAngel.WavemakerRandom2( Port6,60,100 );
    ReefAngel.StandardHeater( Port7,778,784 );
    ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,15,100,15) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(8,30,20,30,15,100,15) );
    ReefAngel.Portal( "Rodasphoto" );
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
Posted: Wed May 22, 2013 8:08 am
Which channel is your UV?
Which port in the relay box is the driver for UVs plugged into?
Posted: Thu May 23, 2013 5:38 am
by Rodasphoto
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <ReefAngel.h>
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.StandardLights( Port2,9,0,21,30 );
    ReefAngel.StandardLights( Port3,9,0,20,30 );
    ReefAngel.StandardLights( Port4,9,0,20,30 );
    ReefAngel.WavemakerRandom( Port5,60,100 );
    ReefAngel.WavemakerRandom( Port6,60,100 );
    ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,0,100,0) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,20,0,0,80,0) );
    ReefAngel.PWM.SetChannel( 2, PWMParabola(9,0,20,0,0,30,0) );
    ReefAngel.PWM.SetChannel( 3, PWMParabola(9,0,20,0,0,30,0) );
    ReefAngel.PWM.SetChannel( 4, PWMParabola(9,0,20,0,0,100,0) );
    ReefAngel.PWM.SetChannel( 5, PWMParabola(9,0,20,0,0,30,0) );
    int x,y;
    x = 15;
    y = 2;
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
#if defined DisplayLEDPWM && ! defined RemoveAllLights
#else // defined DisplayLEDPWM && ! defined RemoveAllLights
#endif // defined DisplayLEDPWM && ! defined RemoveAllLights
The UV are on channel 5
Posted: Thu May 23, 2013 8:07 am
The last parameter on the parabola function will define the % on the off cycle.
So, let's say you want it to be 5%, you would use this:
   ReefAngel.PWM.SetChannel( 5, PWMParabola(9,0,20,0,0,30,5) );
Posted: Mon May 27, 2013 9:17 am
by Rodasphoto
Finally changed the code and it worked. I was wondering if moon phases were possible?
Posted: Mon May 27, 2013 9:29 am
Do you have enough resolution for moonphases?
What is the % you would use for full moon?
