UV LEDs as moonlights
- Rodasphoto
- Contact:
How can I program my UV chips to stay on as moonlights after completing a parabolic day cycle?
- Rodasphoto
- Contact:
Re: UV LEDs as moonlights
ReefAngel.FeedingModePorts = Port5Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 840 );
ReefAngel.StandardLights( Port2,9,0,21,5 );
ReefAngel.StandardLights( Port3,9,0,21,30 );
ReefAngel.StandardLights( Port4,9,0,21,30 );
ReefAngel.WavemakerRandom1( Port5,60,100 );
ReefAngel.WavemakerRandom2( Port6,60,100 );
ReefAngel.StandardHeater( Port7,778,784 );
ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,15,100,15) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(8,30,20,30,15,100,15) );
ReefAngel.Portal( "Rodasphoto" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Which channel is your UV?
Which port in the relay box is the driver for UVs plugged into?
- Rodasphoto
- Contact:
The UV are on channel 5#include <ReefAngel_Features.h>
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.StandardLights( Port2,9,0,21,30 );
ReefAngel.StandardLights( Port3,9,0,20,30 );
ReefAngel.StandardLights( Port4,9,0,20,30 );
ReefAngel.WavemakerRandom( Port5,60,100 );
ReefAngel.WavemakerRandom( Port6,60,100 );
ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,0,100,0) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,20,0,0,80,0) );
ReefAngel.PWM.SetChannel( 2, PWMParabola(9,0,20,0,0,30,0) );
ReefAngel.PWM.SetChannel( 3, PWMParabola(9,0,20,0,0,30,0) );
ReefAngel.PWM.SetChannel( 4, PWMParabola(9,0,20,0,0,100,0) );
ReefAngel.PWM.SetChannel( 5, PWMParabola(9,0,20,0,0,30,0) );
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
The last parameter on the parabola function will define the % on the off cycle.
So, let's say you want it to be 5%, you would use this:
ReefAngel.PWM.SetChannel( 5, PWMParabola(9,0,20,0,0,30,5) );
- Rodasphoto
- Contact:
Finally changed the code and it worked. I was wondering if moon phases were possible?
Do you have enough resolution for moonphases?
What is the % you would use for full moon?
