UV LEDs as moonlights
Rodasphoto
Post by Rodasphoto »
How can I program my UV chips to stay on as moonlights after completing a parabolic day cycle?
Re: UV LEDs as moonlights
Can you post your code?
Rodasphoto
    ReefAngel.FeedingModePorts = Port5Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
    InternalMemory.OverheatTemp_write( 840 );
    ReefAngel.StandardLights( Port2,9,0,21,5 );
    ReefAngel.StandardLights( Port3,9,0,21,30 );
    ReefAngel.StandardLights( Port4,9,0,21,30 );
    ReefAngel.WavemakerRandom1( Port5,60,100 );
    ReefAngel.WavemakerRandom2( Port6,60,100 );
    ReefAngel.StandardHeater( Port7,778,784 );
    ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,15,100,15) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(8,30,20,30,15,100,15) );
    ReefAngel.Portal( "Rodasphoto" );
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
    // Parameters
    // Main Relay Box
    // Date and Time
Which channel is your UV?
Which port in the relay box is the driver for UVs plugged into?
Rodasphoto
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <Salinity.h>
#include <RF.h>
#include <IO.h>
#include <ORP.h>
#include <AI.h>
#include <PH.h>
#include <WaterLevel.h>
#include <ReefAngel.h>
////// Place global variable code below here
////// Place global variable code above here
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.StandardLights( Port2,9,0,21,30 );
    ReefAngel.StandardLights( Port3,9,0,20,30 );
    ReefAngel.StandardLights( Port4,9,0,20,30 );
    ReefAngel.WavemakerRandom( Port5,60,100 );
    ReefAngel.WavemakerRandom( Port6,60,100 );
    ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,0,100,0) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(9,0,20,0,0,80,0) );
    ReefAngel.PWM.SetChannel( 2, PWMParabola(9,0,20,0,0,30,0) );
    ReefAngel.PWM.SetChannel( 3, PWMParabola(9,0,20,0,0,30,0) );
    ReefAngel.PWM.SetChannel( 4, PWMParabola(9,0,20,0,0,100,0) );
    ReefAngel.PWM.SetChannel( 5, PWMParabola(9,0,20,0,0,30,0) );
    int x,y;
    x = 15;
    y = 2;
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
    // Parameters
#if defined DisplayLEDPWM && ! defined RemoveAllLights
#else // defined DisplayLEDPWM && ! defined RemoveAllLights
#endif // defined DisplayLEDPWM && ! defined RemoveAllLights
    // Main Relay Box
    TempRelay &= ReefAngel.Relay.RelayMaskOff;
    TempRelay |= ReefAngel.Relay.RelayMaskOn;
    // Date and Time
The UV are on channel 5
The last parameter on the parabola function will define the % on the off cycle.
So, let's say you want it to be 5%, you would use this:
   ReefAngel.PWM.SetChannel( 5, PWMParabola(9,0,20,0,0,30,5) );
Rodasphoto
Finally changed the code and it worked. I was wondering if moon phases were possible?
Do you have enough resolution for moonphases?
What is the % you would use for full moon?
