I need help modifiying this Cloud Effect PDE
02vetteboy
Post by 02vetteboy »
Hi,
I am still trying to get my head wraped around this whole coding thing and need some help changing this PDE file to use just channel 0 and 1 on the PWM expansion module. I want to run the day light LED's off channel 0 and the Actinic LED's off channel 1. THank you for all the help and such a great community. One more question. When I go to add this to my Reef Angel PDE file does this just get out in the setup and Loop sections. I guess the first part of the code is what is throwing me off a bit on its location.
Duston
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
//Start of PWM Expansion Code Header
// This is just how we are going to reference the PWM expansion ports within the code.
// You can change the labels if you would like, just as long as they are changed all throughout the code too.
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
// Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={
  0,0,0,0,0,0};
//End of PWM Expansion Code Header
  PWMChannel[LEDPWM0]=PWMSlope(10,30,22,00,0,50,40,PWMChannel[LEDPWM0]);
  PWMChannel[LEDPWM1]=PWMSlope(10,00,22,15,0,50,40,PWMChannel[LEDPWM1]);
  PWMChannel[LEDPWM2]=PWMSlope(11,0,21,30,0,50,40,PWMChannel[LEDPWM2]);
  PWMChannel[LEDPWM3]=PWMSlope(11,0,20,00,0,50,40,PWMChannel[LEDPWM3]);
  CheckCloud();
  PWMExpansion(LEDPWM0,int(2.55*PWMChannel[LEDPWM0]));
  PWMExpansion(LEDPWM1,int(2.55*PWMChannel[LEDPWM1]));
  PWMExpansion(LEDPWM2,int(2.55*PWMChannel[LEDPWM2]));
  PWMExpansion(LEDPWM3,int(2.55*PWMChannel[LEDPWM3]));
//  ReefAngel.LCD.DrawText(0,255,120,120,PWMChannel[LEDPWM1]);
//  ReefAngel.LCD.DrawText(0,255,35,120,PWMChannel[LEDPWM1]);
//  ReefAngel.LCD.DrawText(0,255,65,120,PWMChannel[LEDPWM2]);
//  ReefAngel.LCD.DrawText(0,255,95,120,PWMChannel[LEDPWM3]);
//Start of PWM slope function code designed for the PWM Expansion module
void PWMExpansion(byte cmd, byte data)
Wire.beginTransmission(8); // transmit to device #2
Wire.send('$'); // sends $
Wire.send(cmd); // sends a value
Wire.send(data); // sends 255
Wire.endTransmission(); // stop transmitting
//End of PWM slope function code designed for the PWM Expansion module
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Actinic_Channels B000001
#define Daylight_Channels B000010
  static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
#ifdef forcecloudcalculation
    if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      for (int a=0;a<6;a++)
          PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
        for (int b=0;b<6;b++)
            else lightningstatus=0;
            if (lightningstatus) PWMChannel[b]=100;
            else PWMChannel[b]=0;
            //delay(10);
            PWMChannel[b]=20;
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
    if (lightningchance)
      int x=0;
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
Duston
Re: I need help modifiying this Cloud Effect PDE
Your code looks good.
Did you try running it?
02vetteboy
This is the code you help another gentalmen with a while back. He is using 4 PWM channels I want to change it to just using the first two channels of the PWM expansion box. I currently do not have the Reef Angel controller with me due to being deployed over seas. I cant wait to get back and have a chance to paly with it.
Duston
You can simply comment out the other channels you don't need.
Like this:
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
byte PWMChannel[]={
  0,0,0,0,0,0};
  //PWMChannel[LEDPWM2]=PWMSlope(11,0,21,30,0,50,40,PWMChannel[LEDPWM2]);
  //PWMChannel[LEDPWM3]=PWMSlope(11,0,20,00,0,50,40,PWMChannel[LEDPWM3]);
  CheckCloud();
  //PWMExpansion(LEDPWM2,int(2.55*PWMChannel[LEDPWM2]));
  //PWMExpansion(LEDPWM3,int(2.55*PWMChannel[LEDPWM3]));
void CheckCloud()
#define Actinic_Channels B000010
#define Daylight_Channels B000001
#else
#endif
      if (cloudchance)
  if (cloudchance)
            //delay(10);
            PWMChannel[b]=20;
      cloudindex++;
      int x=0;
      int x=0;
  cstart*=60;
  cend*=60;
02vetteboy
Thank you Roberto for the quick reply.
So one last question. Do I just past this in the setup and loop sections?
Duston
No, this is it.
You can use as is. :)
It's got everything in there.
All you need to do is get your relay functions in this code, like StandardLights, which would go in the loop section.
