halide and actnics turning off during the day
neuro
Post by neuro »
For the past week (and maybe at other times), the halides and my actinics are turning off during the day.
I have my overheat temp set at 84.5 deg, but it hasn't even gotten that warm today. Nothing seems to be amiss.
Can anyone help me understand what I'm doing wrong?
My code is as follows:
// ports by name
#define halide 1
#define actinics 2
#define mainPump 3
#define skimmer 4
#define pump1 5
#define pump2 6
#define doser1 7
#define doser2 8
#define ato Box1_Port1
#define gfo Box1_Port2
#define unused3 Box1_Port3
#define unused4 Box1_Port4
#define pump3 Box1_Port5
#define pump4 Box1_Port6
#define heater1 Box1_Port7
#define heater2 Box1_Port8
#define halide 1
#define actinics 2
#define unused3 3
#define unused4 4
#define pump1 5 // off
#define pump4 6 // off
#define doser1 7
#define doser2 8
#define heater1 Box1_Port2
#define skimmer Box1_Port3
#define heater2 Box1_Port4
#define pump2 Box1_Port5
#define pump3 Box1_Port6
#define gfo Box1_Port7
#define mainPump Box1_Port8
// mainPump, skimmer, pump2, pump3, ato, gfo
ReefAngel.FeedingModePortsE[0] = Port1Bit | Port3Bit | Port7Bit | Port8Bit;
// mainPump, Skimmer, all 4 pumps, all 2 dosers, ato, gfo
ReefAngel.WaterChangePorts = Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port4Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port2Bit;
ReefAngel.Relay.On( mainPump );
ReefAngel.Relay.On( skimmer );
ReefAngel.Relay.Off( pump1 );
ReefAngel.Relay.On( pump2 );
ReefAngel.Relay.On( pump3 );
ReefAngel.Relay.Off( pump4 );
ReefAngel.Relay.On( gfo );
ReefAngel.Relay.Off( unused3 );
ReefAngel.Relay.Off( unused4 );
ReefAngel.DayLights( halide );
ReefAngel.ActinicLights( actinics );
ReefAngel.DosingPumpRepeat1( doser1 );
ReefAngel.DosingPumpRepeat2( doser2 );
// ReefAngel.StandardATO( ato );
ReefAngel.StandardHeater( heater1 );
ReefAngel.StandardHeater( heater2 );
// set single ato
ReefAngel.SingleATO(true,ato,60,0);
if (ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(ato);
ReefAngel.Relay.DelayedOn( skimmer );
ReefAngel.Relay.DelayedOn( ato );
ReefAngel.Relay.DelayedOn( gfo );
ReefAngel.Portal( "neuro" );
int x,y;
// Relay Expansion
Re: halide and actnics turning off during the day
Does the res status led light up?
neuro
Post by neuro »
I'll check next time.
I check my portal through my droid and that's when I noticed my lights are overridden to off.
I'll update the next time it happens
