I there,
I can figure most things out but can't see much on the IO expansion relay.
I have one and want to do 2 things.
I want to have a button ( on press ) start feed mode or another result, and on press again it stops it.
Also i want other outputs to be status LEDs so how do i know what input / output etc it controls and what to listen for for button press?
IO Expansion Coding
Re: IO Expansion Coding
That's my bad...
We never had nobody doing output in the past, so we never improved the firmware on the expansion module.
http://forum.reefangel.com/viewtopic.php?f=3&t=3045
So, if you want to pickup the slack and improve the firmware, we can move forward and get this wrapped up.
Want to try?
JoelIreland
Ill see what i can do.
So as far as detecting a button press, what would be my best option?
You could do something like this:
if (ReefAngel.IO.GetChannel(0) && ReefAngel.DisplayedMenu==FEEDING_MODE)
ButtonPress++;
ReefAngel.FeedingModeStart();
JoelIreland
So one end of button goes into channel 0 the other into one of the ground input?
Thanks.
Thanks.
JoelIreland
this is what i have ( head and loop )
<!-- HEAD -->
<!-- LOOP -->
// First channel on left and 1st ground on left. It a push button when it on i want moon lights ( for test ) to turn on.
Moon lights are also on timer but this should over ride?
if(ReefAngel.IO.GetChannel(0)){
ReefAngel.Relay.On(MOON_LIGHTS);
<!-- HEAD -->
<!-- LOOP -->
That's fine, but this override will only work if it is after your moonlight function.
