IO Expansion Coding
Posted: Fri Jun 14, 2013 4:52 pm
by JoelIreland
I there,
I can figure most things out but can't see much on the IO expansion relay.
I have one and want to do 2 things.
I want to have a button ( on press ) start feed mode or another result, and on press again it stops it.
Also i want other outputs to be status LEDs so how do i know what input / output etc it controls and what to listen for for button press?
Re: IO Expansion Coding
Posted: Fri Jun 14, 2013 5:49 pm
That's my bad...
We never had nobody doing output in the past, so we never improved the firmware on the expansion module.
http://forum.reefangel.com/viewtopic.php?f=3&t=3045
So, if you want to pickup the slack and improve the firmware, we can move forward and get this wrapped up.
Want to try?
Posted: Fri Jun 14, 2013 6:07 pm
by JoelIreland
Ill see what i can do.
So as far as detecting a button press, what would be my best option?
Posted: Fri Jun 14, 2013 6:14 pm
You could do something like this:
  if (ReefAngel.IO.GetChannel(0) && ReefAngel.DisplayedMenu==FEEDING_MODE)
    ButtonPress++;
    ReefAngel.FeedingModeStart();
Posted: Fri Jun 14, 2013 7:26 pm
by JoelIreland
So one end of button goes into channel 0 the other into one of the ground input?
Thanks.
Posted: Fri Jun 14, 2013 7:29 pm
Yeap :)
Posted: Fri Jun 14, 2013 11:47 pm
by JoelIreland
this is what i have ( head and loop )
<!-- HEAD -->
<!-- LOOP -->
// First channel on left and 1st ground on left. It a push button when it on i want moon lights ( for test ) to turn on.
Moon lights are also on timer but this should over ride?
if(ReefAngel.IO.GetChannel(0)){
ReefAngel.Relay.On(MOON_LIGHTS);
Posted: Sat Jun 15, 2013 8:18 am
That's fine, but this override will only work if it is after your moonlight function.
