thanks.if i am going to mix,i only need the Jebao cables to work?For both dimming systems?(analog and pwm).
is it possible to work with 3 pumps,and every pump has its own program/modus?
2 pumps work equal and another one works as wavebox. Is that possible?
The libraries currently have support built in to control many pumps but with only 2 modes. Sync/Anti-Sync. You could manually setup control for the 3rd. You could in theory run 8 jaebo's
