Speedwave, wp40, and feed mode
Drs1210
I was thinking about getting one of those speedwave pumps for my return once the new ones come out. I was wondering if anybody had a code for the speedwave to run as their return? What I want was that when I hit feed mode, the speedwave and the wp40 would slow down to a predetermined speed for a certain length of time
Re: Speedwave, wp40, and feed mode
Try this:
Sent from my Galaxy S3 using Tapatalk 2
ReefAngel.PWM.SetActinic(30);
Drs1210
Thanks Roberto! How would it work if i wanted it to automatically go into feeding mode a couple of times a day?
Try this:
if (now()%86400==36000) ReefAngel.FeedingModeStart(); // 36000 is number of seconds from midnight
Drs1210
So would that come on at 10:00 A.M.? If I wanted two feeding times would I just use the same line and just change the seconds?
Drs1210
I was wanting to use this code but I wanted to have two feedings a day instead of one
Could I just add this for a second feeding?
This is my current code. How would I incoperate those two lines into mine? I also want it to slow down my wp40, and my future dc return pump while it is in feed mode, then return back to normal.
Would this code work for what I'm wanting to do
if (now()%86400==61200) ReefAngel.FeedingModeStart(); // 61200 is number of seconds from midnightCode: Select all
// Define Relay Ports by Name
#define KalkDoser 1
#define WCEmpty 2
#define Autotopoff 3
#define Refugium 4
#define KalkStirrer 5
#define WCFill 6
#define Heater 7
#define Return 8
#define RODIValve Box1_Port1
#define Skimmer Box1_Port2
#define GACReactor Box1_Port3
#define GFOReactor Box1_Port4
#define Unused Box1_Port5
#define Unused Box1_Port6
#define Unused Box1_Port7
#define Unused Box1_Port8
byte wpMode;
int WCstatus;
ReefAngel.AddDateTimeMenu();
ReefAngel.PHMin=546;//PH7.0
ReefAngel.PHMax=734;//PH10.0
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit | Port4Bit;
InternalMemory.OverheatTemp_write( 810 );
ReefAngel.Timer[1].SetInterval(180);
ReefAngel.Relay.On( Return );
ReefAngel.Relay.On( Skimmer );
ReefAngel.Relay.On( GACReactor );
ReefAngel.Relay.On( GFOReactor );
CheckPower(); // Monitor for power outages
ReefAngel.PWM.SetChannel( 0, PWMSlope(9,30,21,30,17,100,60,0) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(9,30,21,30,17,100,60,0) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(9,30,21,30,17,100,60,0) );
ReefAngel.PWM.SetChannel( 3, PWMSlope(9,30,21,30,17,100,60,0) );
ReefAngel.PWM.SetChannel( 4, PWMSlope(9,30,21,30,17,100,60,0) );
ReefAngel.PWM.SetChannel( 5, PWMSlope(9,30,21,30,17,100,60,0) );
ReefAngel.WaterLevelATO(Port3,180,54,56);
if (ReefAngel.LowATO.IsActive()) ReefAngel.Relay.On(RODIValve);
if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(RODIValve);
ReefAngel.DosingPumpRepeat( Port1,0,45,6 );
if (ReefAngel.Params.PH>=850) ReefAngel.Relay.Off(KalkDoser);
ReefAngel.StandardLights( Port4,20,0,8,0 );
ReefAngel.Relay.Set(Port5,now()%7200<900);
ReefAngel.StandardHeater( Port7,780,785 );
if (hour()>=6 && hour()<8)
ReefAngel.PWM.SetDaylight( TidalSwellMode(70,true) ); // Tidal Swell at 70% on sync mode
ReefAngel.PWM.SetActinic( TidalSwellMode(70,false) ); // Tidal Swell at 70% on anti-sync mode
wpMode=0;
else if (hour()>=8 && hour()<9)
ReefAngel.PWM.SetDaylight( ReefCrestMode(65,20,true) ); // ReefCrest at 65% +/- 20 on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(65,20,false) ); // ReefCrest at 65% +/- 20 on anti-sync mode
wpMode=1;
else if (hour()>=9 && hour()<13)
ReefAngel.PWM.SetDaylight( ElseMode(60,30,true )); // ElseMode on sync mode, 60 +/- 30%
ReefAngel.PWM.SetActinic( ElseMode(60,30,false )); // ElseMode on anti-sync mode, 60 +/- 30%
wpMode=3;
else if (hour()>=13 && hour()<16)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(75,90,2000,true) ); // Nutrient Transport on sync mode
ReefAngel.PWM.SetActinic( NutrientTransportMode(75,90,2000,false) ); // Nutrient Transport on anti-sync mode
wpMode=2;
else if (hour()>=16 && hour()<20)
wpMode=3;
else if (hour()>=20 && hour()<21)
wpMode=1;
else if (hour()>=21 && hour()<23)
wpMode=0;
ReefAngel.PWM.SetDaylight( SineMode(40,55,30,true) ); // Sine at 40% 55% with for 30s on sync mode
ReefAngel.PWM.SetActinic( SineMode(40,55,30,false) ); // Sine at 40% 55% with for 30s on anti sync mode
wpMode=4;
if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE)
if (WCstatus==-1)
ReefAngel.Timer[1].Start();
WCstatus=0;
ReefAngel.Relay.On(WCEmpty);
WCstatus=1;
if (ReefAngel.WaterLevel.GetLevel()<=30 && WCstatus>0 && WCstatus<10) WCstatus++;
if (ReefAngel.WaterLevel.GetLevel()<=30 && WCstatus==10)
WCstatus=11;
ReefAngel.Relay.Off(WCEmpty);
ReefAngel.Relay.On(WCFill);
if (ReefAngel.WaterLevel.GetLevel()<=79 && WCstatus>10 && WCstatus<20) WCstatus++;
if (ReefAngel.WaterLevel.GetLevel()>79 && WCstatus==20)
ReefAngel.Relay.Off(WCFill);
ButtonPress++;
WCstatus=-1;
ReefAngel.Portal("Drs1210");
ReefAngel.ShowInterface(); // Display everything on the LCD screen
void CheckPower() {
static boolean powerOutage=false;
// Power Outage - turn off everything
if (!ReefAngel.Relay.IsRelayPresent(EXP1_RELAY)) // Expansion Relay NOT present
powerOutage=true;
ReefAngel.Relay.Off(Refugium);
ReefAngel.Relay.Off(KalkStirrer);
ReefAngel.Relay.Off(Heater);
ReefAngel.Relay.Off(Skimmer);
ReefAngel.Relay.Off(GACReactor);
ReefAngel.Relay.Off(GFOReactor);
// Power Restored - Turn things back on
if (powerOutage && ReefAngel.Relay.IsRelayPresent(EXP1_RELAY))
LastStart=now();
powerOutage=false;
ReefAngel.Relay.On(Return);
ReefAngel.Relay.On(Skimmer);
ReefAngel.Relay.On(GACReactor);
ReefAngel.Relay.On(GFOReactor);
byte x = 6;
byte y = 2;
byte t;
char text[7];
ReefAngel.LCD.DrawDate(6, 3);
ReefAngel.LCD.DrawText(COLOR_BLACK,255,56,83, "Res");
ReefAngel.LCD.DrawText(COLOR_GREEN,255, 45, 83, "H");
ReefAngel.LCD.DrawText(COLOR_GREEN,255, 45, 91, "I");
ReefAngel.LCD.DrawText(COLOR_RED,255, 77, 83, "L");
ReefAngel.LCD.DrawText(COLOR_RED,255, 77, 91, "O");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 75, "--------------------");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 98, "--------------------");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 78, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 86, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 95, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 78, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 86, "|");
ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 95, "|");
ReefAngel.LCD.DrawText(0,255,10,30,"Tank");
ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 91, 40, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,8,68,"WC");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_CHOCOLATE, 25, 68, 10);
ReefAngel.LCD.DrawText(0,255,66,68,"Room");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_MEDIUMORCHID, 94, 68, 10);
ReefAngel.LCD.DrawText(0,255,15,83,"WL");
ConvertNumToString(text, ReefAngel.WaterLevel.GetLevel(),1);
ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 10, 91, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,26,91," %");
// WP40 Mode
ReefAngel.LCD.DrawText(0,255,18,12,"Jebao WP40 Mode:");
ReefAngel.LCD.Clear(COLOR_WHITE, 1, 21, 132, 21);
if (wpMode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255, 23, 21,"Tidal Swell");
else if (wpMode == 1) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255, 25, 21,"Reef Crest");
else if (wpMode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255, 8, 21,"Nutrient Trnsp.");
else if (wpMode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255, 30, 21,"Else Mode");
else if (wpMode == 4) ReefAngel.LCD.DrawLargeText(COLOR_RED,255, 30, 21,"Sine Mode");
ReefAngel.LCD.DrawText(0,255,96,83,"WP40");
ConvertNumToString(text, ReefAngel.PWM.GetActinicValue(),1);
ReefAngel.LCD.DrawLargeText(COLOR_OLIVE, 255, 99, 91, text, Num8x8);
ReefAngel.LCD.DrawText(0,255,115,91," %");
// Main Relay box
ReefAngel.LCD.DrawOutletBox(14, 106, TempRelay);
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 14, 118, TempRelay );
ReefAngel.LCD.FillCircle(57,94,3,COLOR_RED);
ReefAngel.LCD.FillCircle(57,94,3,COLOR_GREEN);
ReefAngel.LCD.FillCircle(70,94,3,COLOR_RED);
ReefAngel.LCD.FillCircle(70,94,3,COLOR_GREEN);
if (WaveSync)
return NewSpeed;
return AntiSpeed;
wpMode=0;
wpMode=1;
wpMode=3;
wpMode=2;
wpMode=3;
wpMode=1;
wpMode=0;
wpMode=4;
// If we are feeding override the schedule
ReefAngel.PWM.SetDaylight(30);
wpMode=5;
else {
ReefAngel.PWM.SetDaylight(100);
wpMode=5;
else {
Drs1210
Anybody have any ideas? I've tried the code I thought was going to work, but I had a lot of errors in it.
Drs1210
Well here is the code I tried. I was getting a lot of 'else' without a previous 'if' along with some others.
#define KalkDoser 1
#define WCEmpty 2
#define Refugium 4
#define WCFill 6
#define Heater 7
#define Return 8
#define Unused Box1_Port3
#define Unused Box1_Port4
byte wpMode;
int WCstatus;
ReefAngel.Relay.On( Return ); // Return Pump
ReefAngel.Relay.On( Skimmer ); // Skimmer
ReefAngel.WaterLevelATO(Port3,120,43,45);
wpMode=0;
wpMode=1;
wpMode=3;
wpMode=2;
wpMode=3;
wpMode=1;
wpMode=0;
wpMode=4;
wpMode=5;
else {
wpMode=5;
else {
if (WCstatus==-1)
WCstatus=0;
WCstatus=1;
if (ReefAngel.WaterLevel.GetLevel()<=15 && WCstatus>0 && WCstatus<10) WCstatus++;
if (ReefAngel.WaterLevel.GetLevel()<=15 && WCstatus==10)
WCstatus=11;
if (ReefAngel.WaterLevel.GetLevel()<=81 && WCstatus>10 && WCstatus<20) WCstatus++;
if (ReefAngel.WaterLevel.GetLevel()>81 && WCstatus==20)
ButtonPress++;
WCstatus=-1;
void CheckPower() {
powerOutage=true;
LastStart=now();
powerOutage=false;
byte x = 6;
byte y = 2;
byte t;
char text[7];
// WP40 Mode
// Main Relay box
// Relay Expansion
if (WaveSync)
return NewSpeed;
return AntiSpeed;
The error should tell you exactly which line is the offending line.
It should also highlight the first one.
Just take a look at the error code and at the offending line.
Most are pretty easy to figure out.
The first error I got from your code is this "sketch_jul13a:161: error: expected `;' before 'wpMode'"
So, on line 161, it is saying that it was expecting a ; sign before the variable wpMode.
In your code, here is line 159,160 and 161:
It is saying that you are missing a ; sign. Can you spot where the missing ; sing is supposed to be?
wpMode=5;
