Page 1 of 2
ATO signal on Portal
Posted: Fri Aug 02, 2013 10:51 am
by Seagals
Are the ATO high and low signals in the web portal supposed to change colors? Another words my ato low actually acts as a low water cutoff fr my main pump. currently I am not using a high water switch.
So if my ATO low is not activated shouldn't the light in the portal be a green light??
Thanks in advance
Re: ATO signal on Portal
Posted: Fri Aug 02, 2013 11:19 am
If it's not activated that means the switch is open which means the light is off / red.
If you want the light to always be green, you could use
ReverseATOLow();
That would also affect the behavior of the IsActive() function though so you'll have to add a ! or remove the ! in your current logic.
Posted: Fri Aug 02, 2013 11:22 am
Portal only update every 5 minutes. So, you float switch needs to be triggered for 5 minutes to show up in the portal.
Posted: Fri Aug 02, 2013 11:23 am
rimai wrote:Portal only update every 5 minutes. So, you float switch needs to be triggered for 5 minutes to show up in the portal.
Seagals wrote:So if my ATO low is not activated shouldn't the light in the portal be a green light??
Think he's asking about the default status of the switch...
Posted: Fri Aug 02, 2013 12:36 pm
by Seagals
[quote="lnevo"]If it's not activated that means the switch is open which means the light is off / red.
Ok thanks so I understand it - on a low water cut off the float is always up (at least supoosed to be). and the light in the portal will indicate as 'red'.
Is my float goes down and triggers low water shuts off the main pump than what color light will be indicated on the portal?
Posted: Fri Aug 02, 2013 1:11 pm
by Sacohen
Greem. The colors of the ATO (by Default) are Red for off or not active and Green for on or active.
Posted: Fri Aug 02, 2013 4:13 pm
by Seagals
lnevo wrote:If it's not activated that means the switch is open which means the light is off / red.
ReverseATOLow();
So the following is my current ATO code for the low water cut off:
static unsigned long lastATOCheck=millis();
if (!ReefAngel.LowATO.IsActive()) lastATOCheck=millis();
if (ReefAngel.LowATO.IsActive() && (millis()-lastATOCheck>2000)) ReefAngel.Relay.RelayMaskOff&=~(Port8Bit | Port7Bit | Port1Bit);
if ( (hour()>=8 && hour()<20))//wavemakers on at 8am and off at 8pm
static unsigned long nexttoggle=now();
static boolean state=false;
int cycle=nexttoggle-now();
ReefAngel.Relay.Set(Port5,state);
if (cycle<0)
nexttoggle+=random(960,1020);//tunzes on for 15-16 mins
state=!state;
if (cycle<10)//10 sec overlap
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
Please let me know if the following changes would give me the green light when low water cut off has enough ater in the sump.:
if (ReefAngel.ReverseLowATO.IsActive()) lastATOCheck=millis();
if (ReefAngel.ReverseLowATO.IsActive() && (millis()-lastATOCheck>2000)) ReefAngel.Relay.RelayMaskOff&=~(Port8Bit | Port7Bit | Port1Bit);
if (cycle<0)
state=!state;
Thanks in Advance :)
Posted: Sat Aug 03, 2013 5:49 am
No. the ReverseATOLow() is just used once. It triggers the code to reverse the behavior. You dont use it in every call.
You still use the isActive the way you did before not like you have now...just reverse the logic with the ! If you had it remove it, if not add it.
Posted: Sat Aug 03, 2013 7:08 am
by Seagals
Unfortunately I am getting a error message when I try to verify. The error code states the following:
'class ReefangelClass' has no member named 'ReverseATOLow()'
I tried it a few different ways but NG. This was the last code I tired I removed the ! before the Reef Angel in the following and added the Reverse: 'if (ReefAngel.ReverseLowATO.IsActive()) lastATOCheck=millis();'
Below is the code:
if (cycle<0)
state=!state;
Any Advice would be appreciated.
Posted: Sat Aug 03, 2013 7:53 am
You are using it incorrectly. Please post your original full code and I'll fix it.
Posted: Sat Aug 03, 2013 8:04 am
All you need is this:
ReefAngel.ReverseATOLow();
if (ReefAngel.LowATO.IsActive()) lastATOCheck=millis();
if (cycle<0)
state=!state;
Posted: Sat Aug 03, 2013 11:02 am
by Seagals
Thanks Inevo, I was able to successfully upload it but the portal still shows a red light on both LW and HW ports - I checked the portal over a duration of several hours figuring the portal needed time to see it but still red.
Here is my entire code If you wouldn't mind please take a look at my code and perhaps lmk where I went wrong thanks.
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding";
prog_char menu1_label[] PROGMEM = "Water Change";
prog_char menu2_label[] PROGMEM = "ATO Clear";
prog_char menu3_label[] PROGMEM = "Overheat Clear";
prog_char menu4_label[] PROGMEM = "PH Calibration";
prog_char menu5_label[] PROGMEM = "Version";
prog_char menu6_label[] PROGMEM = "Clear Low Water";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label };
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.DisplayVersion();
void MenuEntry7()
ReefAngel.Relay.RelayMaskOff=255;
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit;
ReefAngel.Relay.On( Port7 );//Chiller
ReefAngel.Relay.On( Port8 );//Main pump
ReefAngel.StandardLights( Port1,8,0,21,0 );//Protein skimmer
ReefAngel.StandardLights( Port2,9,0,21,30 );
ReefAngel.StandardLights( Port3,11,0,20,30 );
ReefAngel.StandardLights( Port4,9,0,21,30 );
ReefAngel.Wavemaker( Port5,960 );
ReefAngel.PWM.SetDaylight( PWMSlope(11,0,20,25,5,70,120,5) );
ReefAngel.PWM.SetActinic( PWMSlope(9,0,21,30,15,88,60,20) );
if (cycle<0)
state=!state;
ReefAngel.Portal( "Seagals" );
Posted: Sat Aug 03, 2013 12:23 pm
This is where feature.txt update may be needed.
Roberto the info was in the pull request:
https://github.com/reefangel/Libraries/pull/89
Take a look at that link and make sure those two lines are in your feature.txt
Posted: Sat Aug 03, 2013 5:37 pm
by Seagals
This is what I found in my library - not sure is this is what you were referring too. It states ATO_LOW_REVERSE - Appreciate your assistance - coding is new to me and after 50+ yrs trying to learn a new language .
LMK - if this helps clarify the issue thanks
* Copyright 2010 Reef Angel / Roberto Imai
* Licensed under the Apache License, Version 2.0 (the "License");
* Updated by: Curt Binder
* Updates Released under Apache License, Version 2.0
#ifndef __RA_ATO_H__
#define __RA_ATO_H__
Auto Top Off Class
class RA_ATOClass
public:
RA_ATOClass();
virtual bool IsActive() = 0;
inline bool IsTopping() { return topping; }
#ifdef ENABLE_ATO_LOGGING
virtual void StartTopping(bool fHighAto = false);
virtual void StopTopping(bool fHighAto = false);
#else
inline void StartTopping() { topping = true; }
inline void StopTopping() { topping = false; }
#endif // ENABLE_ATO_LOGGING
unsigned long Timer;
#ifdef REEFTOUCHDISPLAY
bool activestatus;
void inline SetActive(bool status) { activestatus=status; }
#endif // REEFTOUCHDISPLAY
private:
bool topping;
class RA_ATOHighClass : public RA_ATOClass
public:
#ifdef ATO_HIGH_REVERSE
inline bool IsActive() { return !activestatus; }
#else // REEFTOUCHDISPLAY
inline bool IsActive() { return digitalRead(highATOPin); }
#else // ATO_HIGH_REVERSE
inline bool IsActive() { return activestatus; }
inline bool IsActive() { return !digitalRead(highATOPin); }
#endif // ATO_HIGH_REVERSE
class RA_ATOLowClass : public RA_ATOClass
public:
#ifdef ATO_LOW_REVERSE
inline bool IsActive() { return digitalRead(lowATOPin); }
#else // ATO_LOW_REVERSE
inline bool IsActive() { return !digitalRead(lowATOPin); }
#endif // ATO_LOW_REVERSE
#if defined WATERLEVELEXPANSION
class RA_ATOWLClass : public RA_ATOClass
public:
inline bool IsActive() { return false; }
#endif // WATERLEVELEXPANSION
#endif // __RA_ATO_H__
Posted: Sat Aug 03, 2013 5:46 pm
I wrote that code and am using it as well. You must be missing the feature.txt line i posted.
You should see a message about it when you compile. If not then its going to do nothing.
Posted: Sat Aug 03, 2013 5:47 pm
lnevo wrote:This is where feature.txt update may be needed.
Posted: Sun Aug 04, 2013 7:19 am
by Seagals
Inevo - I may have misunderstood was your last email directed towards Roberto? or me? because at this point I did all I know how to do with my limited knowledge
Posted: Sun Aug 04, 2013 9:26 am
Its directed to both. Find the feature.txt file and add the two lines. Mentioned in the link posted. Re-compile and you should see the "feature" listed when you compile.
Posted: Sun Aug 04, 2013 12:22 pm
by Seagals
Thanks but thing is I am kinda lost at this point what I found yesterday was all I have and will need Roberto's input.
Roberto - when you have a moment please offer me some help - thanks
Posted: Sun Aug 04, 2013 12:26 pm
I'm not so sure what you are trying to accomplish.
Are you trying to invert the colors from red to green?
Is that it?
Posted: Sun Aug 04, 2013 12:52 pm
Ok nevermind. Just put this in your code
#define ATO_LOW_REVERSE
That should trigger it manually.
Posted: Sun Aug 04, 2013 1:25 pm
Using defines on INO code does not get the feature included...
It would be too easy if it worked this way :)
That's this exact reason why I had to come up with the auto-selection of features based on the feature.txt file.
Posted: Sun Aug 04, 2013 1:28 pm
That sucks :(
Posted: Sun Aug 04, 2013 1:42 pm
by Seagals
thanks guys but if its to much trouble don't worry about it - I would have liked the light on the portal to be green on my low water cut off indicating (to me at least) that all was ok. but it sounds like its to much trouble - so lets just leave it as is - thanks
Posted: Sun Aug 04, 2013 2:25 pm
Just find the feature.txt file in your Documents\Arduino folder. You just need to add two lines to it.
I think it should be in updates folder?
Posted: Sun Aug 04, 2013 3:28 pm
by Seagals
ok Lee I found two folders in updates - One was called 'features' and the other was called 'source'
the one with 'source' had the github stuff
now the question is do I add https://github.com/reefangel/Libraries/pull/89 if so, where?
https://raw.github.com/reefangel/librar ... 307RTC.cpp
https://raw.github.com/reefangel/librar ... S1307RTC.h
https://raw.github.com/reefangel/librar ... ywords.txt
https://raw.github.com/reefangel/librar ... readme.txt
https://raw.github.com/reefangel/librar ... kiaLCD.cpp
https://raw.github.com/reefangel/librar ... NokiaLCD.h
https://raw.github.com/reefangel/librar ... LCD/README
https://raw.github.com/reefangel/librar ... neWire.cpp
https://raw.github.com/reefangel/librar ... /OneWire.h
https://raw.github.com/reefangel/librar ... 610LCD.cpp
https://raw.github.com/reefangel/librar ... s6610LCD.h
https://raw.github.com/reefangel/librar ... s6610LCD.o
https://raw.github.com/reefangel/librar ... LCDInv.cpp
https://raw.github.com/reefangel/librar ... 10LCDInv.h
https://raw.github.com/reefangel/librar ... e/Time.cpp
https://raw.github.com/reefangel/librar ... ime/Time.h
https://raw.github.com/reefangel/librar ... trings.cpp
https://raw.github.com/reefangel/librar ... Readme.txt
https://raw.github.com/reefangel/librar ... Alarms.cpp
https://raw.github.com/reefangel/librar ... meAlarms.h
https://raw.github.com/reefangel/librar ... /README.md
https://raw.github.com/reefangel/librar ... /AI/AI.cpp
https://raw.github.com/reefangel/librar ... er/AI/AI.h
https://raw.github.com/reefangel/librar ... DCPump.cpp
https://raw.github.com/reefangel/librar ... p/DCPump.h
https://raw.github.com/reefangel/librar ... lobals.cpp
https://raw.github.com/reefangel/librar ... /Globals.h
https://raw.github.com/reefangel/librar ... midity.cpp
https://raw.github.com/reefangel/librar ... Humidity.h
https://raw.github.com/reefangel/librar ... EEPROM.cpp
https://raw.github.com/reefangel/librar ... alEEPROM.h
https://raw.github.com/reefangel/librar ... /IO/IO.cpp
https://raw.github.com/reefangel/librar ... er/IO/IO.h
https://raw.github.com/reefangel/librar ... ED/LED.cpp
https://raw.github.com/reefangel/librar ... /LED/LED.h
https://raw.github.com/reefangel/librar ... Memory.cpp
https://raw.github.com/reefangel/librar ... y/Memory.h
https://raw.github.com/reefangel/librar ... RP/ORP.cpp
https://raw.github.com/reefangel/librar ... /ORP/ORP.h
https://raw.github.com/reefangel/librar ... /PH/PH.cpp
https://raw.github.com/reefangel/librar ... er/PH/PH.h
https://raw.github.com/reefangel/librar ... RA_ATO.cpp
https://raw.github.com/reefangel/librar ... O/RA_ATO.h
https://raw.github.com/reefangel/librar ... A_Colors.h
https://raw.github.com/reefangel/librar ... ystick.cpp
https://raw.github.com/reefangel/librar ... Joystick.h
https://raw.github.com/reefangel/librar ... RA_PWM.cpp
https://raw.github.com/reefangel/librar ... M/RA_PWM.h
https://raw.github.com/reefangel/librar ... Sensor.cpp
https://raw.github.com/reefangel/librar ... mpSensor.h
https://raw.github.com/reefangel/librar ... A_Wifi.cpp
https://raw.github.com/reefangel/librar ... /RA_Wifi.h
https://raw.github.com/reefangel/librar ... fAngel.cpp
https://raw.github.com/reefangel/librar ... eefAngel.h
https://raw.github.com/reefangel/librar ... gel/README
https://raw.github.com/reefangel/librar ... Features.h
https://raw.github.com/reefangel/librar ... /Arial12.h
https://raw.github.com/reefangel/librar ... alBold20.h
https://raw.github.com/reefangel/librar ... alBold24.h
https://raw.github.com/reefangel/librar ... uch/f8x8.h
https://raw.github.com/reefangel/librar ... h/f12x12.h
https://raw.github.com/reefangel/librar ... h/f15x22.h
https://raw.github.com/reefangel/librar ... /Fat32.cpp
https://raw.github.com/reefangel/librar ... ch/Fat32.h
https://raw.github.com/reefangel/librar ... ch/mmc.cpp
https://raw.github.com/reefangel/librar ... ouch/mmc.h
https://raw.github.com/reefangel/librar ... ch/Icons.h
https://raw.github.com/reefangel/librar ... gel_Logo.h
https://raw.github.com/reefangel/librar ... fTouch.cpp
https://raw.github.com/reefangel/librar ... eefTouch.h
https://raw.github.com/reefangel/librar ... SDFile.cpp
https://raw.github.com/reefangel/librar ... h/SDFile.h
https://raw.github.com/reefangel/librar ... estImage.h
https://raw.github.com/reefangel/librar ... /Relay.cpp
https://raw.github.com/reefangel/librar ... ay/Relay.h
https://raw.github.com/reefangel/librar ... /RF/RF.cpp
https://raw.github.com/reefangel/librar ... er/RF/RF.h
https://raw.github.com/reefangel/librar ... RT_PWM.cpp
https://raw.github.com/reefangel/librar ... M/RT_PWM.h
https://raw.github.com/reefangel/librar ... linity.cpp
https://raw.github.com/reefangel/librar ... Salinity.h
https://raw.github.com/reefangel/librar ... /Timer.cpp
https://raw.github.com/reefangel/librar ... er/Timer.h
https://raw.github.com/reefangel/librar ... rLevel.cpp
https://raw.github.com/reefangel/librar ... terLevel.h
https://raw.github.com/reefangel/librar ... RA_TFT.cpp
https://raw.github.com/reefangel/librar ... T/RA_TFT.h
https://raw.github.com/reefangel/librar ... A_Tilt.cpp
https://raw.github.com/reefangel/librar ... /RA_Tilt.h
https://raw.github.com/reefangel/librar ... uchLCD.cpp
https://raw.github.com/reefangel/librar ... TouchLCD.h
https://raw.github.com/reefangel/librar ... /RA_TS.cpp
https://raw.github.com/reefangel/librar ... TS/RA_TS.h
http://www.reefangel.com/update/files/u ... eature.txt
http://www.reefangel.com/update/files/R ... loaded.ino
http://www.reefangel.com/update/files/t ... ibsVer.jar
http://www.reefangel.com/update/files/t ... loaded.jar
http://www.reefangel.com/update/files/t ... ection.png
http://www.reefangel.com/update/files/t ... _small.png
http://www.reefangel.com/update/files/t ... el-5.1.jar
http://www.reefangel.com/update/files/t ... -2.0b4.jar
http://www.reefangel.com/update/files/t ... tMaker.jar
http://www.reefangel.com/update/files/t ... -1.0.3.jar
http://www.reefangel.com/update/files/t ... l/jace.jar
http://www.reefangel.com/update/files/t ... -tasks.jar
http://www.reefangel.com/update/files/t ... /Regex.jar
http://www.reefangel.com/update/files/t ... weaver.jar
http://www.reefangel.com/update/files/t ... Wizard.jar
http://www.reefangel.com/update/files/t ... ata/AI.png
http://www.reefangel.com/update/files/t ... w_back.png
http://www.reefangel.com/update/files/t ... w_next.png
http://www.reefangel.com/update/files/t ... cancel.png
http://www.reefangel.com/update/files/t ... layout.xml
http://www.reefangel.com/update/files/t ... a/moon.png
http://www.reefangel.com/update/files/t ... rabola.png
http://www.reefangel.com/update/files/t ... ttings.png
http://www.reefangel.com/update/files/t ... imming.png
http://www.reefangel.com/update/files/t ... Radion.png
http://www.reefangel.com/update/files/t ... ra_ato.png
http://www.reefangel.com/update/files/t ... zontal.png
http://www.reefangel.com/update/files/t ... /slope.png
OR the following is what I found in the 'features' folder -
PWMEXPANSION,ReefAngel.PWM.SetChannel,Dimming Expansion Module
DisplayLEDPWM,ReefAngel.PWM.,Dimming Signal
AI_LED,ReefAngel.AI.,Aqua Illumination Communication
IOEXPANSION,ReefAngel.IO.,I/O Expansion Module
RFEXPANSION,ReefAngel.RF.,RF Expansion Module
SALINITYEXPANSION,ReefAngel.Params.Salinity,Salinity Expansion Module
ORPEXPANSION,ReefAngel.Params.ORP,ORP Expansion Module
wifi,ReefAngel.Portal,Wifi Attachment
wifi,CheckWifi(),Wifi Attachment
wifi,ReefAngel.AddWifi(),Wifi Attachment
CUSTOM_MAIN,DrawCustomMain,Custom Main Screen
CUSTOM_VARIABLES,ReefAngel.CustomVar,Custom Variable
ENABLE_EXCEED_FLAGS,_Exceed_Flag,Exceed Flagging
FONT_8x8,FONT_8x8,Extra Font - Medium Size (8x8 pixels)
FONT_8x8,ReefAngel.LCD.DrawLargeText,Extra Font - Medium Size (8x8 pixels)
FONT_8x16,FONT_8x16,Extra Font - Large Size (8x16 pixels)
FONT_12x16,FONT_12x16,Extra Font - Extra Large Size (12x16 pixels)
FONT_12x16,ReefAngel.LCD.DrawHugeText,Extra Font - Extra Large Size (12x16 pixels)
NUMBERS_8x8,NUMBERS_8x8,Extra Font - Numbers Only - Medium Size (8x8 pixels)
NUMBERS_8x16,NUMBERS_8x16,Extra Font - Numbers Only - Large Font (8x16 pixels)
NUMBERS_12x16,NUMBERS_12x16,Extra Font - Numbers Only - Extra Large Font (12x16 pixels)
NUMBERS_16x16,NUMBERS_16x16,Extra Font - Numbers Only - Huge Font (16x16 pixels)
NUMBERS_16x16,ReefAngel.LCD.DrawHugeNumbers,Extra Font - Numbers Only - Huge Font (16x16 pixels)
DateTimeSetup,ReefAngel.SetupDateTime,Date/Time Setup Menu
DateTimeSetup,ReefAngel.AddDateTimeMenu,Date/Time Setup Menu
SaveRelaysPresent,ReefAngel.Relay.IsRelayPresent,Relay Box presence check
RelayExp,Box1_,Relay Expansion Module
RelayExp,Box2_,Relay Expansion Module
RelayExp,Box3_,Relay Expansion Module
RelayExp,Box4_,Relay Expansion Module
RelayExp,Box5_,Relay Expansion Module
RelayExp,Box6_,Relay Expansion Module
RelayExp,Box7_,Relay Expansion Module
RelayExp,Box8_,Relay Expansion Module
RelayExp,ReefAngel.Relay.RelayDataE,Relay Expansion Module
CUSTOM_MENU,MenuEntry,Custom Menu
PHEXPANSION,ReefAngel.Params.PHExp,PH Expansion Module
COLORS_PDE,AddCustomColors(),Custom Colors
WATERLEVELEXPANSION,ReefAngel.WaterLevel.,Water Level Expansion Module
SetupCalibrateChoicePH,ReefAngel.SetupCalibrateChoicePH,Calibrate pH Menu with Choices
MOONPHASELABEL,MoonPhaseLabel,Moon Phase Label
PWMEXPANSION,ReefAngel.PWM.GetChannelValue,Dimming Expansion Module
PWMEXPANSION,ReefAngel.PWM.Channel0,Dimming Expansion Module
PWMEXPANSION,ReefAngel.PWM.Channel1,Dimming Expansion Module
PWMEXPANSION,ReefAngel.PWM.Channel2,Dimming Expansion Module
PWMEXPANSION,ReefAngel.PWM.Channel3,Dimming Expansion Module
PWMEXPANSION,ReefAngel.PWM.Channel4,Dimming Expansion Module
PWMEXPANSION,ReefAngel.PWM.Channel5,Dimming Expansion Module
COLORS_PDE,ReefAngel.AddCustomColors,Custom Colors
RFEXPANSION,ReefAngel.AddRFExpansion(),RF Expansion Module
DATETIME24,ReefAngel.Display24h(),Display 24h Time
SETUP_CALIBRATEPH_CHOICE,ReefAngel.UseFlexiblePhCalibration,Calibrate pH Menu with Choices
REEFANGEL_MINI,ReefAngel.Mini,Reef Angel Mini
SALINITYEXPANSION,ReefAngel.SetupCalibrateSalinity,Salinity Expansion Module
I2C_LIB,I2C.h,I2C Library
WATERLEVELEXPANSION,ReefAngel.WaterLevelATO,Water Level Expansion Module
REEFTOUCH,ReefAngel.Touch(),Reef Angel Touch
REEFTOUCHDISPLAY,ReefAngel.TouchDisplay(),Reef Angel Touch Display
NOWIFI,ReefAngel.NoWifi(),Disable Wifi Attachment
EVOLUTION,ReefAngel.Evolution(),Reef Angel Evolution
NOSD,ReefAngel.NoSD(),Disable SD Card
NOTILT,ReefAngel.NoTilt(),Disable Tilt
I2CMASTER,ReefAngel.UpdateTouchDisplay(),Reef Angel I2C Master
BUSCHECK,ReefAngel.AddBusCheck(),I2C Bus Check
RADION_COMM,ReefAngel.RF.SetChannel,Ecotech Radion Communication
HUMIDITYEXPANSION,ReefAngel.Humidity.GetLevel,Humidity Expanion Module
DCPUMPCONTROL,ReefAngel.DCPump,DC Pump Control (Jebao/Tunze)
DisplayLEDPWM,ReefAngel.DCPump,Dimming Signal
PWMEXPANSION,ReefAngel.DCPump.ExpansionChannel,Dimming Expansion Module
LEAKDETECTOREXPANSION,ReefAngel.IsLeakDetected(),Rope Leak Detector Expansion
LEAKDETECTOREXPANSION,ReefAngel.LeakShutoffPorts,Rope Leak Detector Expansion
Sorry for the back and forth and I really appreciate you spending so much time on the weekend helping me with this.
If you can let me know if these are the correct folders, if so, please suggest what I need to add and where - thanks Sooooooooooooo much!
Posted: Sun Aug 04, 2013 4:16 pm
Thats not it. You are looking for a file not folder called feature.txt
You want to add these two lines:
ATO_LOW_REVERSE,ReefAngel.ReverseATOLow,Reverse ATO Low
ATO_HIGH_REVERSE,ReefAngel.ReverseATOHigh,Reverse ATO High
Posted: Sun Aug 04, 2013 4:22 pm
The second one you showed "features"
Its not a folder but contents are correct.
Add the two lines i gave you above.
Posted: Mon Aug 05, 2013 1:26 pm
by Seagals
YES it worked!!!! Thank you - It makes so much more sense for the light to be green meaning its safe - that's awesome thanks
