ecoxotic Stunner LED Strips
ecam
Post by ecam »
Stunner
http://www.drsfostersmith.com/product/p ... atid=21598
inline-dimmer
Guys, i purchased this stunner strip to go with my t5s. it has an inline dimmer http://www.drsfostersmith.com/product/p ... 4326&rel=1. Because of this can i get the reef angel to control it so that i can set up moon phases?
Re: ecoxotic Stunner LED Strips
I don't think you can but I'm not 100% positive. I have the Panorama Pro and a Stunner strip but haven't tried using the inline dimmer module. You probably could do that but might have to splice into the wires to control the signal going to the modules. Others may have to chime in on this topic though too.
ecam
Post by ecam »
Thanks Binder for the glimmer of hope... Can Roberto or lnevo confirm or deny this before i splice the dimmer cable.. thanks
Sorry, I never seen this fixture before.
I highly doubt you can do anything with it though.
I don't think they are dimmable by 3rd party controllers.
You should ask the manufacturer.
Doubt it. Any manufacturer right now is gonna include their own controller, be APEX Ready (analog) or be pot only. Nobody is making externally controllable pwm fixtures.
ecam
Post by ecam »
lnevo wrote:Doubt it. Any manufacturer right now is gonna include their own controller, be APEX Ready (analog) or be pot only. Nobody is making externally controllable pwm fixtures.
But if its analog ready... cant i control it through my Analog dimming channels?
If it is in fact 0-10v analog then yes.
johniii
Post by johniii »
Just browsing ecoxotics website. It appears the are using pwm on the line voltage 12-24vdc. In order to use the RA I believe a circuit would have to be built to switch a transistor with the RA pwm. The ecoxotic signal will need to pass through the collector/emitter of the transistor.
