ecoxotic Stunner LED Strips
Posted: Sun Sep 01, 2013 7:01 pm
by ecam
Stunner
http://www.drsfostersmith.com/product/p ... atid=21598
inline-dimmer
Guys, i purchased this stunner strip to go with my t5s. it has an inline dimmer
http://www.drsfostersmith.com/product/p ... 4326&rel=1. Because of this can i get the reef angel to control it so that i can set up moon phases?
Re: ecoxotic Stunner LED Strips
Posted: Sun Sep 01, 2013 9:06 pm
I don't think you can but I'm not 100% positive. I have the Panorama Pro and a Stunner strip but haven't tried using the inline dimmer module. You probably could do that but might have to splice into the wires to control the signal going to the modules. Others may have to chime in on this topic though too.
Posted: Mon Sep 02, 2013 4:19 pm
by ecam
Thanks Binder for the glimmer of hope... Can Roberto or lnevo confirm or deny this before i splice the dimmer cable.. thanks
Posted: Mon Sep 02, 2013 4:58 pm
Sorry, I never seen this fixture before.
I highly doubt you can do anything with it though.
I don't think they are dimmable by 3rd party controllers.
You should ask the manufacturer.
Posted: Mon Sep 02, 2013 5:38 pm
Doubt it. Any manufacturer right now is gonna include their own controller, be APEX Ready (analog) or be pot only. Nobody is making externally controllable pwm fixtures.
Posted: Wed Sep 04, 2013 10:01 am
by ecam
lnevo wrote:Doubt it. Any manufacturer right now is gonna include their own controller, be APEX Ready (analog) or be pot only. Nobody is making externally controllable pwm fixtures.
But if its analog ready... cant i control it through my Analog dimming channels?
Posted: Wed Sep 04, 2013 10:11 am
If it is in fact 0-10v analog then yes.
Posted: Wed Sep 04, 2013 4:27 pm
by johniii
Just browsing ecoxotics website. It appears the are using pwm on the line voltage 12-24vdc. In order to use the RA I believe a circuit would have to be built to switch a transistor with the RA pwm. The ecoxotic signal will need to pass through the collector/emitter of the transistor.
