WIFI module won't save static IP
Posted: Sun Sep 08, 2013 3:30 pm
Here are my results when I use the wifi attachment setup utility - when I use the graphical utility and try to set the IP by hand using set ip address XXXXXX it still won't stay after I hit save..... help?
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM3
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM3
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM3
< CMD
> factory RESET
< factory RESEô
< Set Factory Defaults
> reboot
< <2.38>
< reboot
Factory Settings Restored
< CMD
> set u b 57600
< set u b 57600
< AOK
< <2.38>
> set s p 0
> save
< <2.38>
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 11 19 3 WiFly_GSX-2.23
< 30 1 10 config
< 31 20 3 WiFly_GSX-2.38
< 51 20 3 WiFly_GSX-2.38
< 71 1 10 user
< 184 Free, Boot=51, Backup=31
< <2.38>
> load user
< load user
< AOK
< <2.38>
> save
< save
< Storing in config
> save
< <2.38>
< save
< Storing in config
< <2.38>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <2.38>
> set w l 5
< set w þ%µ
< AOK
< <2.38>
> set w s SSID
< set w s SSID
< AOK
< <2.38>
> set w p password
< set w p password
< AOK
< <2.38>
< set w mÈ00000000000000000000000000
< AOK
< <2.38>
< set ft¸ address 1½8¿Ì³3÷³wYw³îÃÃAOK
< <2.38>
> save
< save
< Storing in config
> reboot
< <2.38>
< reboot
< CMD
> show n
< show n
< SSid=estanoche
< Chan=1
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=WPA2
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=1
< <2.38>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=0.0.0.0:2000
< NM=0.0.0.0
< GW=0.0.0.0
< HOST=69.198.171.165:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <2.38>
> reboot
< reboot
Found router SBG6580
Port 2000 is now being forwarded to 0.0.0.0
