New design layout
New design layout
Hi Guys,
I'm changing the design layout of the default main screen and would like to hear comments before I release it.
It only fits on the RA+ board though.
Here is what you need to do:
Update your libraries with the current dev branch of our libraries: https://github.com/reefangel/Libraries/archive/dev.zip
Update the features.txt with the attached file. It is located at \Documents\Arduino\update
Add this to your setup() section:
  ReefAngel.Use2014Screen();
Make sure you don't have any custom main screen code, so you need have to delete the functions DrawCustomGraph and DrawCustomMain.
Let me know your thoughts :)
If you have any ideas to improve the layout, please speak up!!!
feature.txt
(5 KiB) Downloaded 935 times
rossbryant1956
Re: New design layout
Post by rossbryant1956 »
can we see a screen shot of what it'll look like?
Yes, please :)
Piper
Post by Piper »
Does the latest dev branch have calibration for the multi-port water level expansion yet?
Let me see what I can do about the photos.
Yes, it does have the calibration.
Sent from my SPH-L710 using Tapatalk 4
Looking forward to pics.
ganjero
Post by ganjero »
Where is the attached file?
Which file?
I didn't have time to take the photos yet.
ganjero
Post by ganjero »
rimai wrote:Which file?
rimai wrote:Update the features.txt with the attached file. It is located at \Documents\Arduino\update
Ahh... forgot to attach it :oops:
It's in there now.
ganjero
Post by ganjero »
Thanks for adding the file.
I will try it and provide feedback. To change the library I just need to replace the folders in \Documents\Ardunio\libraries with the ones in the zip file, correct?
Thank you Roberto.
correct
ganjero
Post by ganjero »
I just installed this.
Feedback so far:
- I found that there is some error displaying my T1.
- Whats is the normal mode screen?
Screenshots (sorry for the low quality cell pics)
I guess I need a better sentence :(
That screen only has 1 option to display, which is lights on mode.
If it is not lights on mode, it will display "Normal mode"
Should I name something else?
Looks great! Gonna mess with my custom screens for sure though...
How are we gonna hook into that?
ganjero
Post by ganjero »
Could the DCPump screen be "live" and show the speeds go up and down?
You can see that in the AP/DP signals.
I guess we could have a new screen dedicated for AP/DP with bars too.
In fact, I think that's what I'll do.
I can't seem to be able to replicate your T1 problem though
ganjero
Post by ganjero »
rimai wrote:I guess we could have a new screen dedicated for AP/DP with bars too.
Awesome
rimai wrote:I can't seem to be able to replicate your T1 problem though
Maybe something in my code? Other screen show fine so I dont think is the screen
Found it :)
Thanks for letting me know!!
I'll fix it on next revision.
Ok, I updated the dev branch with the dimming channels in a separate screen.
ganjero
Post by ganjero »
I will try it when I get home. Is there a way to chart the AP/DP? I would like to see how the wave patterns are behaving through the day.
Custom screens...hows that gonna work???
ganjero wrote:Roberto,
http://forum.reefangel.com/status/chart ... ilter=pwmd
The controller only sends data every 5 minutes though
lnevo wrote:Custom screens...hows that gonna work???
Doesn't change a thing.
Just like custom screens bypass the original one, it will bypass this one too.
Also, if you don't add ReefAngel.Use2014Screen(); the new screen is not enabled anyway.
Is there a way to tap into the new screen though and add stuff? Maybe like a DrawCustomGraph() ?
Would love to get all the new stuff but keep some functionality...
Or can I do my own DrawCustomMain() and call a Draw function for the screens you've created?
ganjero
Post by ganjero »
T1 display issue fixed and Dimming ports bars screen added.
Thanks Roberto
New screenshots
Bruz4023
Post by Bruz4023 »
lnevo wrote:Is there a way to tap into the new screen though and add stuff? Maybe like a DrawCustomGraph() ?
Did we get an answer to this i would love to alter the new screens! I love how they look but somethings are not named properly for my system!
