This may be a dumb question, but I got lost in the threads and couldn't find my answer.
I have a wifi expansion in addition to RA+. I generated the code that I am currently using with RA Wizard. I want to make changes to the parameters such as on off times for moonlight, but the code does not have them in there. Are there any basic code set that I can start playing with. Everyone has fancy ATO switches etc, which does not apply to me.
I have 2 temp sensors, 1 PH sensor, 1 Moonlight, 1 DawnDusk, 1 Daylight, 1 Skimmer, 2 pumps (Nanocube Stock pumps) alternating, 1 Heater and 1 Vortech.
I am not allowed to use my web banner url yet, here is the screen shot of what I have.
Can I get a basic code that I can tinker with?
RA Wizard equivalent of Code
OceanWolf
Onur
Onur
Re: RA Wizard equivalent of Code
Can you post your code?
Sent from my SPH-L710 using Tapatalk
OceanWolf
It is down below. I am also sorry that I should have posted that in the PDE/INO Files section. Roberto, can you move it?rimai wrote:Can you post your code?
Onur
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.AddStandardMenu();
ReefAngel.MoonLights( Port1 );
ReefAngel.ActinicLights( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.MoonLights( Port4 );
ReefAngel.Wavemaker1( Port5 );
ReefAngel.Relay.Set( Port6, !ReefAngel.Relay.Status( Port5 ) );
ReefAngel.ActinicLights( Port8 );
ReefAngel.Portal( "Oceanwolf" );
Onur
Onur
OceanWolf
Thanks Roberto. I switched to hard coded settings, now I can see the times. I also added feeding times.rimai wrote:When you generate the code, use the hard coded settings.
Do you know why the RAGen does not pick up the Gen 3 LCD? I use the code line you suggested in an earlier thread.
ReefAngel.StandardLights( Port1,23,0,1,0 );
ReefAngel.StandardLights( Port2,11,30,23,0 );
ReefAngel.StandardLights( Port3,12,0,22,0 );
ReefAngel.StandardLights( Port4,8,0,23,0 );
ReefAngel.WavemakerRandom( Port5,90,120 );
ReefAngel.StandardHeater( Port7,710,790 );
ReefAngel.StandardLights( Port8,8,0,23,0 );
// Feeding mode at 8 Am and 6 PM//
if ( (now()%86400==28800) || (now()%86400==64800) ) {
ReefAngel.FeedingModeStart();
Onur
Onur
If you upload the code once with this line, you really don't need it ever again
OceanWolf
Thanks. I always worried that I will forget to add it.rimai wrote:This line is only really need once in the lifetime of the controller.Code: Select all
Now I don't have to worry.
Onur
Onur
Onur
