RA Wizard equivalent of Code
Posted: Sun Oct 20, 2013 12:05 pm
by OceanWolf
This may be a dumb question, but I got lost in the threads and couldn't find my answer.
I have a wifi expansion in addition to RA+. I generated the code that I am currently using with RA Wizard. I want to make changes to the parameters such as on off times for moonlight, but the code does not have them in there. Are there any basic code set that I can start playing with. Everyone has fancy ATO switches etc, which does not apply to me.
I have 2 temp sensors, 1 PH sensor, 1 Moonlight, 1 DawnDusk, 1 Daylight, 1 Skimmer, 2 pumps (Nanocube Stock pumps) alternating, 1 Heater and 1 Vortech.
I am not allowed to use my web banner url yet, here is the screen shot of what I have.
Can I get a basic code that I can tinker with?
Re: RA Wizard equivalent of Code
Posted: Sun Oct 20, 2013 1:25 pm
Can you post your code?
Sent from my SPH-L710 using Tapatalk
Posted: Sun Oct 20, 2013 4:47 pm
by OceanWolf
rimai wrote:Can you post your code?
It is down below. I am also sorry that I should have posted that in the PDE/INO Files section. Roberto, can you move it?
Onur
    InternalMemory.LCDID_write(0);
    ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.AddStandardMenu();
    ReefAngel.MoonLights( Port1 );
    ReefAngel.ActinicLights( Port2 );
    ReefAngel.DayLights( Port3 );
    ReefAngel.MoonLights( Port4 );
    ReefAngel.Wavemaker1( Port5 );
    ReefAngel.Relay.Set( Port6, !ReefAngel.Relay.Status( Port5 ) );
    ReefAngel.ActinicLights( Port8 );
    ReefAngel.Portal( "Oceanwolf" );
Posted: Sun Oct 20, 2013 5:02 pm
When you generate the code, use the hard coded settings.
Posted: Sun Oct 20, 2013 10:35 pm
by OceanWolf
rimai wrote:When you generate the code, use the hard coded settings.
Thanks Roberto. I switched to hard coded settings, now I can see the times. I also added feeding times.
Do you know why the RAGen does not pick up the Gen 3 LCD? I use the code line you suggested in an earlier thread.
    ReefAngel.StandardLights( Port1,23,0,1,0 );
    ReefAngel.StandardLights( Port2,11,30,23,0 );
    ReefAngel.StandardLights( Port3,12,0,22,0 );
    ReefAngel.StandardLights( Port4,8,0,23,0 );
    ReefAngel.WavemakerRandom( Port5,90,120 );
    ReefAngel.StandardHeater( Port7,710,790 );
    ReefAngel.StandardLights( Port8,8,0,23,0 );
    // Feeding mode at 8 Am and 6 PM//
if ( (now()%86400==28800) || (now()%86400==64800) ) {
ReefAngel.FeedingModeStart();
Posted: Mon Oct 21, 2013 8:41 am
This line is only really need once in the lifetime of the controller.
If you upload the code once with this line, you really don't need it ever again :)
Posted: Mon Oct 21, 2013 7:48 pm
by OceanWolf
Thanks. I always worried that I will forget to add it.
Now I don't have to worry. :lol:
Onur
