Internal memory in portal isnt updating my system.
Dctrojan
Post by Dctrojan »
The internal memory control on portal seems to be not working. Ive been trying to change the light setting through portal and it doesnt give a error, just a few windows pop up. They say on the top just the url to reef angel and under that it says:
mb263,64
then when you click ok it all goes away and nothing changes.
Portal does allow me to change turn off and on my relays though, im very confused.
Dctrojan
Re: Internal memory in portal isnt updating my system.
Post by Dctrojan »
This is the code the wizard generates except for the WavemakerRandom1 which I added to randomize the circulation pumps I have. It seems to make them work even though the wizard didn't have the option to select this under wave makers
I don't see the code
Dctrojan
Post by Dctrojan »
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit | Port8Bit;
ReefAngel.MoonLights( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.ActinicLights( Port4 );
ReefAngel.WavemakerRandom1( Port5,20,60 );
ReefAngel.WavemakerRandom2( Port6,25,65 );
ReefAngel.Relay.Set( Port7, !ReefAngel.Relay.Status( Port3 ) );
ReefAngel.StandardHeater( Port8 );
ReefAngel.Portal( "Dctrojan" );
int x,y;
ReefAngel.LCD.DrawMonitor( 15, 11, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 11, ReefAngel.Params );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,48, "PHE:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,48, 100 );
ReefAngel.LCD.DrawOutletBox( 12, 65, TempRelay );
Refresh the page to reload the js file and try again.
New2novas
Post by New2novas »
i'm having the same problem, say the portal is displaying tidal swell but i had requested long pulse in the wizard and it is in fact doing the long pulse routine, nothing i change in the portal has effect
@new2novas:
Did you go with the internal memory settings?
Dctrojan
Post by Dctrojan »
All i did was refresh the code and reapply it to the controller and its working now.
New2novas
Post by New2novas »
Sorry to hijack but....im not sure what you mean, are you referring to where it asks if I want to store the code? What's weird is it worked a couple days ago but not the past few
When you generate your code with the wizard, you can choose to save setting in the code, which is recommended for beginners until you are more familiar with the controller and internal memory, which is what the Portal will use to change settings.
You must choose internal memory settings choice if you want to change setting with the Portal.
New2novas
Post by New2novas »
That did it....as always thanks
