#include <RT_PWM.h>
#include <avr/pgmspace.h>
byte RoyalBluePWMValue=0;
byte WhitePWMValue=0;
byte BluePWMValue=0;
byte PinkPWMValue=0;
prog_char menu3_label[] PROGMEM = "Overheat Clear";
prog_char menu5_label[] PROGMEM = "Date / Time";
prog_char menu6_label[] PROGMEM = "Version";
prog_char menu7_label[] PROGMEM = "Lighting";
menu0_label, menu1_label, menu2_label,
menu3_label, menu4_label, menu5_label,
menu6_label,menu7_label//, menu7_label, menu8_label
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.DisplayVersion();
void MenuEntry8()
ReefAngel.PWMSetPercent(byte p);
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port8Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardATO( Port1,1800 );
ReefAngel.StandardLights( Port3,7,0,22,0 );
ReefAngel.StandardLights( Port4,11,0,23,0 );
ReefAngel.StandardHeater( Port7,780,790 );
RoyalBluePWMValue= PWMSlope(7,0,23,0,0,100,90,RoyalBluePWMValue) ;
WhitePWMValue=PWMParabola(10,0,22,0,0,100,WhitePWMValue) ;
BluePWMValue=PWMParabola(8,30,20,0,0,100,BluePWMValue) ;
PinkPWMValue=PWMSlope(7,30,22,30,0,100,90,PinkPWMValue) ;
CheckCloud();
ReefAngel.PWM.SetChannel( 0, RoyalBluePWMValue);
ReefAngel.PWM.SetChannel( 1, WhitePWMValue );
ReefAngel.PWM.SetChannel( 2, BluePWMValue );
ReefAngel.PWM.SetChannel( 3, PinkPWMValue );
ReefAngel.Portal( "Bruz4023" );
