Help with Custom Menus
Posted: Fri Oct 18, 2013 8:19 pm
				So I am having successes with the custom menus but what i want is an option to turn my lights on at anytime to full brightness. it says that the class PWMSetPercent doesnt exist but you had said in the manual that it does. what am I missing
#include <RT_PWM.h>
#include <avr/pgmspace.h>
byte RoyalBluePWMValue=0;
byte WhitePWMValue=0;
byte BluePWMValue=0;
byte PinkPWMValue=0;
  prog_char menu0_label[] PROGMEM = "Feeding";
  prog_char menu2_label[] PROGMEM = "ATO Clear";
  prog_char menu3_label[] PROGMEM = "Overheat Clear";
  prog_char menu4_label[] PROGMEM = "PH Calibration";
  prog_char menu5_label[] PROGMEM = "Date / Time";
  prog_char menu6_label[] PROGMEM = "Version";
  prog_char menu7_label[] PROGMEM = "Lighting";
  menu0_label, menu1_label, menu2_label,
  menu3_label, menu4_label, menu5_label,
  menu6_label,menu7_label//, menu7_label, menu8_label
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ReefAngel.OverheatClear();
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupDateTime();
void MenuEntry7()
ReefAngel.DisplayVersion();
void MenuEntry8()
ReefAngel.PWMSetPercent(byte p);
    ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.StandardATO( Port1,1800 );
    ReefAngel.StandardLights( Port3,7,0,22,0 );
    ReefAngel.StandardLights( Port4,11,0,23,0 );
    ReefAngel.StandardHeater( Port7,780,790 );
    RoyalBluePWMValue= PWMSlope(7,0,23,0,0,100,90,RoyalBluePWMValue) ;
    WhitePWMValue=PWMParabola(10,0,22,0,0,100,WhitePWMValue) ;
    BluePWMValue=PWMParabola(8,30,20,0,0,100,BluePWMValue) ;
    PinkPWMValue=PWMSlope(7,30,22,30,0,100,90,PinkPWMValue) ;
    CheckCloud();
    ReefAngel.PWM.SetChannel( 0, RoyalBluePWMValue);
    ReefAngel.PWM.SetChannel( 1, WhitePWMValue );
    ReefAngel.PWM.SetChannel( 2, BluePWMValue );
    ReefAngel.PWM.SetChannel( 3, PinkPWMValue  );
    ReefAngel.Portal( "Bruz4023" );
