I am receiving the following when ever I Try to upload to the controller. This occurs after it reboots the controller.
Error Uploading
Re: Error Uploading
Apparently the TTL cable only works if it is plugged in on the pins all the way to the right on the controller...
Re: Error Uploading
Make sure you select the correct board type. This was causing me issues at first. Once the I selected the correct board type the upload went fine.
Re: the cable, user manual, page 20
Connect the USB-TTL converter cable to your Reef Angel Controller.
Note: Make sure you connect the cable as the picture below. The black wire must be the right most position and the 2 left most pins must be unconnected. Failure to do so can lead to damage to your ReefAngel Controller head unit and/or cable.
AJ
AJ
