Minimum ATO Run Time
ReEfnWrX
Post by ReEfnWrX »
Hey guys,
so I am running a single ATO switch setup and what I have found is that sometimes the switch will bounce trigger on/off/on/off etc.. This does not happen every single time.
I was hoping to implement a minimum amount of time the Controller has to wait between cycling the ATO Relay port on.
Example it turns on then turns off... no matter what the switch does, the controller has to wait lets say, one hour before listening to the switch and turning the ATO Relay on.
Here is my current code.
    ReefAngel.FeedingModePorts = Port1Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port7Bit;
    ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port4Bit;
    ReefAngel.Relay.On( Port5 );
    ReefAngel.StandardHeater( Port1,777,780 );
    ReefAngel.StandardLights( Port2,21,30,12,0 );
    ReefAngel.StandardLights( Port3,12,0,21,30 );
    ReefAngel.MHLights( Port4,14,0,20,30,5 );
    ReefAngel.SingleATO( true,Port7,4542,0 );
    ReefAngel.StandardLights( Port8,12,0,21,45 );
if (hour()>=11 && hour()<20)   // 11am - 8pm
    ReefAngel.PWM.SetDaylight( ElseMode(65,20,true) ); // ReefCrest at 65% +/- 20% on sync mode
else if (hour()>=20 && hour()<23)    // 8pm - 11pm
    ReefAngel.PWM.SetDaylight( NutrientTransportMode(30,90,500,true) ); // Nutrient Transport 30%minspeed - 90%maxspeed - 500ms
else if (hour()>=23 || hour()<11)    // 11pm - 11am
    ReefAngel.PWM.SetDaylight( ElseMode(40,15,true) ); // ReefCrest at 40% +/- 15% on sync mode
    ReefAngel.Portal( "ReEfnWrX" );
  static unsigned long LastChange=millis();        // Set the inital time that the last change occurred
  static int Delay = random( 500, 3000);           // Set the initial delay
  static int NewSpeed = MidPoint;                  // Set the initial speed
  static int AntiSpeed = MidPoint;                 // Set the initial anti sync speed
  if ((millis()-LastChange) > Delay)               // Check if the delay has elapsed
    Delay=random(500,5000);                        // If so, come up with a new delay
    int ChangeUp = random(Offset);                 // Amount to go up or down
    if (random(100)<50)                            // 50/50 chance of speed going up or going down
    LastChange=millis();                           // Reset the time of the last change
  if (WaveSync)
    return NewSpeed;
    return AntiSpeed;
Re: Minimum ATO Run Time
Theres a few solutions out there to do the very thing...
Roberto...it may be time to add a time arg to the singleato function, i think it gets asked enough times.
ReEfnWrX
Post by ReEfnWrX »
I searched but did not find anything
Curt was the one who created the function and I'm pretty sure that it already has it.
The last argument is the timer in hours.
I need to double check when I get back.
I think its hours too...i think that forces it to run every x hours but not 100%.
ReEfnWrX
Post by ReEfnWrX »
I do not want to force it to run every X hours. I just want to control that when it is triggered, it will stay on for at least a few minutes...
Pretty much just stop it from bouncing between off and on 5 times in a second..
If you said one hour it would do just that...basically it would run 24x a day and the low point would replace the low switch and the single you are using would act like the high. Its the same thing really but maybe it should be an int and be in minutes...so you can say dont run if you just ran within 10 minutes ago.
ReEfnWrX
Post by ReEfnWrX »
exactly, i want to tell it not to run if it ran X time ago... But what is the code for that? I cannot find any posts with it
The SingleATO function does just that. It allows you to set an interval so that the function only triggers 1 time during that interval so you don't bounce back and forth like you have experienced. Here's the comment for the function:
        If the switch is active, the float is opposite of the 2 wires,
                Check if we are not currently topping, if we are not check if we can run
                If we have an hour interval, check if we can run
                If we can run, activate the pump because we need water
        Otherwise the switch is not active, we need to see if we are currently topping
                If we are topping, then we need to stop the pump because we are topped off
So a sample usage would be this:
ReefAngel.SingleATO(true, 1, 60, 1);
This statement would be to:
  • Use the LOW switch
  • Activate Port 1
  • Use a 60 second timeout where if it runs for more than 60 seconds, the timeout will kick up an error
  • Can only top off 1 time no more than 1 hour apart. This means that no matter when the ATO triggers, once it runs it cannot run again for at least 1 hour. This is based off of the last time it ran, so this can fluctuate throughout the day.
Here's the link to the ATO reference thread: http://forum.reefangel.com/viewtopic.php?f=7&t=240
Hope this helps clarify things.
ReEfnWrX
Post by ReEfnWrX »
Yeah I have read through that link but it doesn't explain the ATO Functions in comparison to the code.
Ah I see, since the Wizard only gives the option to modify timeout and not the minimal interval between on's. so in my code the last function is 0 which if I am correct, that is the function I need to change.
Thanks for clarifying
ReEfnWrX wrote:Yeah I have read through that link but it doesn't explain the ATO Functions in comparison to the code.
Yeah, I don't think the Wizard allows you to change the minimum interval. Placing 0 in it makes it run whenever it activates.
You need to change the parameter 0 in the function to be the hour interval that you wish. That should take care of things for you.
And I will look at the ATO guide and see if I can add that part in clarifying the hour interval.
I just updated the ATO guide to include this code sample and some further explanations.
