So I compiled a new file for my reefangel with the wizard, Is this file really too big or am I doing something wrong. I just have the standard reefangel
ReefAngel.WaterChangePorts = Port1Bit | Port4Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
InternalMemory.OverheatTemp_write( 909 );
ReefAngel.Relay.On( Port4 );
ReefAngel.SingleATO( false,Port1,128,0 );
ReefAngel.StandardLights( Port2,9,0,21,0 );
ReefAngel.StandardLights( Port3,10,0,20,0 );
ReefAngel.StandardLights( Port5,9,0,21,0 );
ReefAngel.Wavemaker( Port6,60 );
ReefAngel.StandardHeater( Port7,751,761 );
ReefAngel.DCPump.SetMode( TidalSwell,50,10 );
ReefAngel.Portal( "ryanmell" );
Is this file really too big?
rossbryant1956
Re: Is this file really too big?
save your file, close and restart arduino, try again. Arduino tends to hold things in memory causing a problem like this. Not saying this file is NOT too big, just something to try.
- Sacohen
Do you have the RS or the RA+?
If you have the RA chances are very good that the file is too big.
The new libraries have a lot in there and it does not leave you much room for your code.
- lnevo
The DCPump class is very large. You could remove it and use the PWM functions directly to control your pumps.
ryanmell
how do I use the PWM functions directly to control my pumps, can I use like crest mode and all of that?
- Sacohen
The wave patterns are in this thread that Roberto created.
http://forum.reefangel.com/viewtopic.ph ... wave+modes
The way you would code Long Pulse on the Daylight Dimming Channel is like this..
ReefAngel.PWM.SetDaylight( LongPulseMode(45,70,10,true));
This is a minimum speed of 45% and maximum speed of 70% with a 10 second duration and the pumps in sync if you had multiple pumps.
Long Pulse
PulseMinSpeed - % for minimal speed
PulseMaxSpeed - % for maximum speed
PulseDuration - Duration (seconds) in which each pulse will be held. The pump will stay at minimal speed for PulseDuration and will stay at maximum speed for PulseDuration.
PulseSync - true if you want to sync pumps to same cycle. one false and one true if you want to anti-sync pumps.
Long Pulse
ryanmell
awesome thanks for the info maybe a little more research on my part and I would have found it
- Sacohen
It's kind of hard to find. I just knew about it because I stumbled on it a while back.
Good luck with it.
Good luck with it.
