Why does my RA keeps going into feeding mode
my RA keeps going into feeding mode can anyone tell me why or what might have cause it to happened?
Re: Why does my RA keeps going into feeding mode
Do you have any wavemaker pumps cycling on/off?
What equipment do you have connected to RA?
Glad someone else is having the same issue. Mine does the same thing, randomly goes into feeding mode all day long.
Hi I do not have any wavemaker cycling on/off. I have Mp40 controlled by rf module and wp40x2 and leds controlled by dimming expansion. The rest of the equipment using relays.
Did you ever get this figured out? Mine was doing the same thing on new years eve.. of course ot the worst possible time when I was leaving for the night...
I moved the return pump to a "always on port on the relay".. but my skimmer was still turning off.. wait 15 mins.. then turned back on... 30 seconds later.. back into feeding mode... Did this for like 24 hours.. now it seems to be back to normal... nothing done on my side
I have a bunch of annoying little issues:
unit randomly goes into feeding mode (this thread)
Wifi was broken.. needed RMA
New Wifi add-on turns off occassionally and usually turns back on a few hours later
Screen goes white but all seems to still work. have to reboot RA to get screen back
Curious if your Feeding Mode issue went away like it seems to have done for me
