No internal Memory found
max455
Post by max455 »
Hello,
I have a problem. I have had my Reef Angel for 18 months or so. Always worked great. I got a new pc and reinstalled the all the software. So I figured I would build a new file as I have made some changes to my setup. I tried to load the example internal memory file and all I get is No memory found. I have run out of ideas.
Greg
Re: No internal Memory found
Upload the InitialInternalMemory located in the Example Codes folder.
max455
Post by max455 »
Hello,
Yes I did that. It seems to reboot and I get the same No Internal Memory error. it uploads with no errors
What is the libraries version you are using?
max455
Post by max455 »
Before the re-install on the new computer I believe it was .96. I am using the internalmemory from the new install
Reef Angel Libraries Found: Development
Reef Angel Libraries Version: 1.1.0
Try this one.
InitialInternalMemory.ino
(6.25 KiB) Downloaded 497 times
max455
Post by max455 »
Worked great! All back up and running.
Thanks for your help!
Greg
