Reset Reef Angel via the web
ufgators2k
My Reef Angel seems to get into a state where the screen is all white. It seems to happen whenever the ATO timeout occurs. Is there a way to remotely reset the device without pulling the plug or reloading the software (via web command)?
Re: Reset Reef Angel via the web
You can do with the latest libraries.
You can use /boot command
ufgators2k
Does this work with the 1.0.9 libraries? The new ones are too big for my old Reef Angel
ufgators2k
- Sacohen
The latest version of the Andriod App has a reboot button on the 1st screen, but I guess you would need the current libraries in order for it to work.
- lnevo
It's nice to have the extra memory. I've always recommended people to get the plus.
ufgators2k
I've been debating for quite a while. I'd like to you use the SunLocation class and the WiFi Alert. Now I will.
- Sacohen
Go with the Plus. The new libraries are getting too big to even put on the standard RA.
ReEfnWrX
I concur! Plus it lets you geek out when you have no other projects to work on =pSacohen wrote:Go with the Plus. The new libraries are getting too big to even put on the standard RA.
- Sacohen
When are there no other projects to work on.
I constantly have 3-4 going and just work on the one I feel like at the time or the one that has to be done before I can go onto the one I want to do.
ufgators2k
Just upgraded. It is SOOO much easier to get a build to fit!
Anyone want to buy a regular ReefAngel board??? LOL...
