Reset Reef Angel via the web
Posted: Tue Nov 26, 2013 7:29 pm
by ufgators2k
My Reef Angel seems to get into a state where the screen is all white. It seems to happen whenever the ATO timeout occurs. Is there a way to remotely reset the device without pulling the plug or reloading the software (via web command)?
Re: Reset Reef Angel via the web
Posted: Tue Nov 26, 2013 7:30 pm
You can do with the latest libraries.
You can use /boot command
Posted: Tue Nov 26, 2013 7:31 pm
by ufgators2k
Does this work with the 1.0.9 libraries? The new ones are too big for my old Reef Angel
Posted: Tue Nov 26, 2013 7:37 pm
negative :(
Posted: Fri Jan 03, 2014 6:58 am
by ufgators2k
You have just made me spend $75 on upgrading. Thanks Roberto... ;-)
Posted: Fri Jan 03, 2014 8:11 am
by Sacohen
The latest version of the Andriod App has a reboot button on the 1st screen, but I guess you would need the current libraries in order for it to work.
Posted: Fri Jan 03, 2014 9:06 am
It's nice to have the extra memory. I've always recommended people to get the plus. :)
Posted: Fri Jan 03, 2014 9:25 am
by ufgators2k
I've been debating for quite a while. I'd like to you use the SunLocation class and the WiFi Alert. Now I will.
Posted: Fri Jan 03, 2014 9:30 am
by Sacohen
Go with the Plus. The new libraries are getting too big to even put on the standard RA.
Posted: Fri Jan 03, 2014 10:03 am
by ReEfnWrX
Sacohen wrote:Go with the Plus. The new libraries are getting too big to even put on the standard RA.
I concur! Plus it lets you geek out when you have no other projects to work on =p
Posted: Fri Jan 03, 2014 10:55 am
by Sacohen
When are there no other projects to work on.
I constantly have 3-4 going and just work on the one I feel like at the time or the one that has to be done before I can go onto the one I want to do.
Posted: Sun Jan 19, 2014 3:22 pm
by ufgators2k
Just upgraded. It is SOOO much easier to get a build to fit!
Anyone want to buy a regular ReefAngel board??? LOL...
