WP25 not working on cable
Posted: Tue Dec 10, 2013 7:49 am
Hi
So obviously i stuffed up royaly somewhere in the wizard to get the 2x WP25 to run, cause they aint coming on at all. Also did the upgrade to RA+
Anybody want to take a look and tell me where I stuffed up
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port4Bit | Port7Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardHeater( Port1 );
ReefAngel.DayLights( Port2 );
ReefAngel.StandardATO( Port3 );
ReefAngel.Relay.DelayedOn( Port7 );
ReefAngel.PWM.Channel0PWMSlope();
ReefAngel.PWM.Channel1PWMSlope();
ReefAngel.PWM.Channel2PWMSlope();
ReefAngel.PWM.Channel3PWMSlope();
ReefAngel.PWM.Channel4PWMSlope();
ReefAngel.PWM.Channel5PWMSlope();
ReefAngel.DCPump.DaylightChannel = AntiSync;
ReefAngel.DCPump.ExpansionChannel[0] = None;
ReefAngel.Portal( "Toolboy" );
