hello
i buy one meanwell P for dim only the daylight
if the thunderstrom and cloud fonction like this
http://forum.reefangel.com/viewtopic.php?f=12&t=288
work on dimmable daylight only
another question i connect the moonlight on the actinic port, how i convert this port to use moonlight fonction
thank again
moonlight+thunderstorm
Re: moonlight+thunderstorm
Yes, you can make it so only daylight channel wouold be part of the storm and clouds
Simply comment out anything
For the moonlights, use this:
