Hi guys,
as far as I understand, the pwm parabola function ramps up and then down.
Is it possible to let the function first ramp down and then up?
For example this:
ReefAngel.PWM.SetDaylight( PWMParabola(10,0,22,0,60,0,0) );
Starting at 60% and then down to 0% and then up to 60% again ?
I just don't want to mess up my unit by uploading the above, hence my question.
Thanks in advance.
Leslie
Parabola reversed, possible ?
- lnevo
Re: Parabola reversed, possible ?
Just do Max-Parabola(...)
So if your max is 60 when the parabola starts at 60 it will be 60-60 so 0 and when its at 0 it will be 60-0 so 0.
lmolenmaker
Thanks for your answer Lee,
But I have no idea what to do with it.
What will be the code for the example below?
Starting at 60% and then down to 0% and then up to 60% again ? (pwm daylight channel, between 10.00 and 22.00 hrs).
I appreciate your help.
Leslie
Leslie
- lnevo
ReefAngel.PWM.SetDaylight( 60 - PWMParabola(10,0,22,0,0,60,0) );
lmolenmaker
Thanks Lee,
I will give it a try. I will report back later.
Leslie
Leslie
