can someone explain to me what the duration does in the code below
if (hour()>=6 && hour()<11)
myRFSetMode(ReefCrest,85,10);
else if (hour()>=11 && hour()<13)
else if (hour()>=13 && hour()<16)
myRFSetMode(Smart_NTM,85,15);
else if (hour()>=16 && hour()<19)
myRFSetMode(ReefCrest,65,10);
myRFSetMode(Lagoon,40,10);
I dont think the current settings are strong enough for my 6ft tank and before i tweak would like to fully understand the function.
Thanks guys
Duration in RF mode
- lnevo
Re: Duration in RF mode
ReefCrest and Lagoon don't use duration on the RF module.
Smart NTM does and i believe its in seconds. I use 5 in my Smart NTM and it works good. I have a 36" tank though
ecam
i guess the question is what exactly is duration and what are the parameters and units. does it go 0 - 100 and measured in seconds?
From the sound of what u said it sounds like its the period of time where the pulse intensity will be maintained. I.e: it will send out a sustain blast every 5 seconds to create a wave.
Is this right
Is this right
ecam
lnevo wrote:ReefCrest and Lagoon don't use duration on the RF module.
So in this code:
what is the 10?
