Can't get weather code working
dlplunkett44
Post by dlplunkett44 »
I'm trying to get the clouds and lightning code working but I am getting the following errors:
sketch_mar01a.cpp:207:5: error: invalid preprocessing directive #PWMExpansion
sketch_mar01a.cpp: In function 'void CheckCloud()':
sketch_mar01a:391: error: a function-definition is not allowed here before '{' token
sketch_mar01a:401: error: expected `}' at end of input
 To be able to use the custom main screen and PWM Expansion, please make sure that you enabled custom main screen and pwm expansion on your features file.
 Open RAGen and make sure you have Custom Main Screen and PWM Expansion checked under the Features tab.
 Or, you can manually edit the file.
 The file is located at "Documents\Arduino\libraries\ReefAngel_Features.h" file and has to include this line in it:
 #define CUSTOM_MAIN
 #define PWMEXPANSION
#define DisplayImages
#define WavemakerSetup
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define StandardLightSetup
//Start of PWM Expansion Code Header
// This is just how we are going to reference the PWM expansion ports within the code.
// You can change the labels if you would like, just as long as they are changed all throughout the code too.
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
// Initial values to all 6 channels at startup. They will always be 0.
byte PWMChannel[]={
  0,0,0,0,0,0};
//byte cloudchance=0;
//byte cloudduration=0;
//int cloudstart=0;
//End of PWM Expansion Code Header
#include <avr/wdt.h>
  ReefAngel.LCD.DrawText(T1TempColor, DefaultBGColor, 15, 10, "T1:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], T1TempColor, 15+18, 10, 10);
  ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, 15, 10+10, "T2:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], T2TempColor, 15+18, 10+10, 10);
  ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, 15, 10+20, "T3:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], T3TempColor, 15+18, 10+20, 10);
  ReefAngel.LCD.DrawText(PHColor, DefaultBGColor, 15+60, 10, "PH:");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, PHColor, 15+78, 10, 100);
  //ATO status
  ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 15+60, 10+20, "Pump:");
  byte highcolor;
  char highstatus[10];
  if ( ReefAngel.HighATO.IsActive() )
       ReefAngel.LCD.DrawText(PHColor, DefaultBGColor, 15+90, 10+20, "ON ");
       ReefAngel.LCD.DrawText(T1TempColor, DefaultBGColor, 15+90, 10+20, "OFF");
  //End ATO status
  ReefAngel.LCD.DrawOutletBox(12, 95, TempRelay);
  //ReefAngel.LCD.DrawOutletBox(12, 35, TempRelay);
  ReefAngel.LCD.DrawText(0,255,15,52,"RB:");
  ReefAngel.LCD.DrawText(0,255,15,62,"BB:");
  ReefAngel.LCD.DrawText(0,255,15,72,"CW:");
  ReefAngel.LCD.DrawText(0,255,15,82,"WW:");
  ReefAngel.LCD.DrawText(0,255,15+20,52,PWMChannel[LEDPWM0]);
  ReefAngel.LCD.DrawText(0,255,15+20,62,PWMChannel[LEDPWM1]);
  ReefAngel.LCD.DrawText(0,255,15+20,72,PWMChannel[LEDPWM2]);
  ReefAngel.LCD.DrawText(0,255,15+20,82,PWMChannel[LEDPWM3]);
  ReefAngel.LCD.DrawText(0,255,15+60,52,"CC:");
  ReefAngel.LCD.DrawText(0,255,15+60,62,"CD:");
  ReefAngel.LCD.DrawText(0,255,15+60,72,"CS:");
 // ReefAngel.LCD.DrawText(0,255,15+80,52,cloudchance);
 // ReefAngel.LCD.DrawText(0,255,15+80,62,cloudduration);
 // ReefAngel.LCD.DrawText(0,255,15+80,72,cloudstart/60);
void setup() {
    ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
    ReefAngel.Relay.On( Port2 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
    //Port 1 = ATO
    //Port 2 = Always On
    //Port 3 = Heater
    //Port 4 = Main Pump
    //Port 5 = Wavemaker
    //Port 6 = Wavemaker
    //Port 7 = Sump Light
    //Port 8 = Feeder Relay
    ReefAngel.StandardHeater( Port3,820,825 );
    ReefAngel.StandardLights( Port7,21,0,7,0 );
    ReefAngel.SingleATO( true,Port1,180,0 );
    ReefAngel.WavemakerRandom(Port5,15,45);
    ReefAngel.WavemakerRandom1(Port6,15,45);
static unsigned long feeding = 0;
if ((now()%SECS_PER_DAY==28800) || (now()%SECS_PER_DAY==50400) || (now()%SECS_PER_DAY==72000)) //if it is 8am or 2pm or 8 pm { ReefAngel.FeedingModeStart(); //START FEEDING MODE } if (ReefAngel.DisplayedMenu==FEEDING_MODE)
if ( feeding == 0 )
feeding = now(); //set the time of the start of feeding to variable feeding } if ((now()-feeding>=60) && (now()-feeding<=61)) //if between 60 and 61 seconds has past { ReefAngel.Relay.On(Port8); //TURN FEEDER RELAY ON } else { ReefAngel.Relay.Off(Port8); //TURN FEEDER RELAY OFF } } else { if ( feeding > 0 ) { feeding = 0; } }
   #PWMExpansion
  PWMChannel[LEDPWM0]=PWMSlope(10,30,22,00,0,50,240,PWMChannel[LEDPWM0]);
  PWMChannel[LEDPWM1]=PWMSlope(10,00,22,15,0,55,240,PWMChannel[LEDPWM1]);
  PWMChannel[LEDPWM2]=PWMSlope(11,0,21,30,0,45,240,PWMChannel[LEDPWM2]);
  PWMChannel[LEDPWM3]=PWMSlope(11,30,20,00,0,50,240,PWMChannel[LEDPWM3]);
  CheckCloud();
  //PWMExpansion(LEDPWM0,int(2.55*PWMChannel[LEDPWM0]));
  //PWMExpansion(LEDPWM1,int(2.55*PWMChannel[LEDPWM1]));
  //PWMExpansion(LEDPWM2,int(2.55*PWMChannel[LEDPWM2]));
  //PWMExpansion(LEDPWM3,int(2.55*PWMChannel[LEDPWM3]));
  //ReefAngel.LCD.DrawText(0,255,5,120,PWMChannel[LEDPWM0]);
  //ReefAngel.LCD.DrawText(0,255,35,120,PWMChannel[LEDPWM1]);
  //ReefAngel.LCD.DrawText(0,255,65,120,PWMChannel[LEDPWM2]);
  //ReefAngel.LCD.DrawText(0,255,95,120,PWMChannel[LEDPWM3]);
    ReefAngel.AddWifi();
void CheckCloud() {
 #define Clouds_Every_X_Days 1
 #define Min_Cloud_Duration 7
 #define Max_Cloud_Duration 15
 #define Min_Clouds_per_Day 3
 #define Max_Clouds_per_Day 5
 #define Actinic_Channels B000001
 #define Daylight_Channels B000010
 //#define printdebug
 // Uncomment this for debug print on Serial Monitor window
 #define forcecloudcalculation
 // Uncomment this to force the cloud calculation to happen in the boot process.
 static byte cloudchance=255;
 static byte cloudduration=0;
 static int cloudstart=0;
 static byte numclouds=0;
 static byte cloudindex=0;
 static int LastNumMins=0;
#ifdef forcecloudcalculation
 if (cloudchance==255)
#else
 #endif
 {  //Pick a random number between 0 and 99
 cloudchance=random(100);
 // If we have cloud today
 if (cloudchance)
 lightningchance=random(100);  // if picked number is greater than Lightning_Change_per_Cloud, we will not have lightning today
 if (lightningchance>Lightning_Change_per_Cloud) lightningchance=0;  }  }  // Now that we have all the parameters for the cloud, let's create the effect
 if (cloudchance)
 //is it time for cloud yet?
 for (int a=0;a<6;a++)
 PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
 if (lightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/2))) && second()<5)  {  for (int b=0;b<6;b++)  {  if (bitRead(Daylight_Channels,b)==1)  {  if (random(100)<20) lightningstatus=1;  else lightningstatus=0;  if (lightningstatus) PWMChannel[b]=100;  else PWMChannel[b]=0;  //delay(10);  }  else  {  PWMChannel[b]=20;  }  }  }  }  if (NumMins(hour(),minute())>(cloudstart+cloudduration))
 cloudindex++;
 if (cloudindex < numclouds)
 if (lightningchance>Lightning_Change_per_Cloud) lightningchance=0;  }  }  }
 int x=0;
 if (lightningchance)
 int x=0;
  cstart*=60;
  cend*=60;
  if (n>cend) return PWMStart;
  //End Cloud & Lighting
dlplunkett44
Re: Can't get weather code working
Ok, i made some formatting adjustments and got rid of all but one error:
sketch_mar01a.cpp:206:5: error: invalid preprocessing directive #PWMExpansion
Here is my new code:
 #define CUSTOM_MAIN
#define VersionMenu
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
byte PWMChannel[]={
  0,0,0,0,0,0};
//int cloudstart=0;
  //ATO status
  byte highcolor;
  //End ATO status
void setup() {
    //Port 1 = ATO
    //Port 3 = Heater
if ( feeding == 0 )
   #PWMExpansion
  CheckCloud();
void CheckCloud() {
#else
 #endif
 if (cloudchance)
 if (cloudchance)
 //delay(10);
 PWMChannel[b]=20;
 cloudindex++;
 int x=0;
 int x=0;
  cstart*=60;
  cend*=60;
dlplunkett44
So I was able to change a few things and get it to compile. When I tried uploading it, I got no errors, but now the screen flashes white then the status led flashes 3 times and it repeats. Please help!
My code is:
 #define CUSTOM_MAIN
#define VersionMenu
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
byte PWMChannel[]={
  0,0,0,0,0,0};
//int cloudstart=0;
  //ATO status
  byte highcolor;
  //End ATO status
  ReefAngel.LCD.DrawText(0,255,15,62,"CW");
  ReefAngel.LCD.DrawText(0,255,15,72,"OCW:");
  ReefAngel.LCD.DrawText(0,255,15,82,"VI:");
//ReefAngel.LCD.DrawText(0,255,15+80,52,cloudchance);
  //ReefAngel.LCD.DrawText(0,255,15+80,62,cloudduration);
  //ReefAngel.LCD.DrawText(0,255,15+80,72,cloudstart/60);
void setup() {
    InternalMemory.OverheatTemp_write( 860 );
    //Port 1 = ATO
    //Port 3 = Heater
    ReefAngel.SingleATO( true,Port1,180,1 );
if ( feeding == 0 )
  // #PWMEXPANSION
//Channel 0 = Blue
//Channel 1 = White
//Channel 2 = OCW
//Channel 3 = Violet
//Channel 4 = Moonlights
//Channel 5 = Not Used
  PWMChannel[LEDPWM0]=PWMSlope(6,0,21,30,1,80,60,PWMChannel[LEDPWM0]);
  PWMChannel[LEDPWM1]=PWMSlope(6,30,20,45,1,60,60,PWMChannel[LEDPWM1]);
  PWMChannel[LEDPWM2]=PWMSlope(6,15,21,00,1,60,90,PWMChannel[LEDPWM2]);
  PWMChannel[LEDPWM3]=PWMSlope(6,0,21,45,0,75,60,PWMChannel[LEDPWM3]);
  ReefAngel.PWM.SetChannel( 4, PWMSlope(20,30,6,30,0,30,60,0) );
  CheckCloud();
void CheckCloud() {
 // In this example, start could after 10:00am
 #define Start_Cloud_After NumMins(10,00)
 // In this example, end could before 7:30pm
 #define End_Cloud_Before NumMins(19,30)
 #define Actinic_Channels B001001
 #define Daylight_Channels B000110
#else
 #endif
 if (cloudchance)
 if (cloudchance)
 //delay(10);
 PWMChannel[b]=20;
 cloudindex++;
 int x=0;
 int x=0;
  cstart*=60;
  cend*=60;
You are missing one } in your code, which ended up all the way in the end and caused ShowInterface() to be inside the if statement.
You must have ShowInterface being called in every loop pass.
dlplunkett44
Thanks!! So that got the screen working, but the clouds/lightning are not working. I watched as the screen said a cloud/lightning should have happened and the lights did not change at all. Here is my updated code:
 #define CUSTOM_MAIN
#define VersionMenu
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
byte PWMChannel[]={
  0,0,0,0,0,0};
//int cloudstart=0;
  //ATO status
  byte highcolor;
  //End ATO status
  ReefAngel.LCD.DrawText(0,255,15,62,"CW:");
  ReefAngel.LCD.DrawText(0,255,15+22,52,PWMChannel[LEDPWM0]);
  ReefAngel.LCD.DrawText(0,255,15+22,62,PWMChannel[LEDPWM1]);
  ReefAngel.LCD.DrawText(0,255,15+22,72,PWMChannel[LEDPWM2]);
  ReefAngel.LCD.DrawText(0,255,15+22,82,PWMChannel[LEDPWM3]);
void setup() {
    //Port 1 = ATO
    //Port 3 = Heater
    if ( feeding == 0 )
  if ( feeding > 0 )
    feeding = 0;
   //#PWMEXPANSION
//Channel 0 = Blue
//Channel 1 = White
//Channel 2 = OCW
  ReefAngel.PWM.SetChannel( 0,PWMChannel[LEDPWM0]);
  ReefAngel.PWM.SetChannel( 1,PWMChannel[LEDPWM1]);
  ReefAngel.PWM.SetChannel( 2,PWMChannel[LEDPWM2]);
  ReefAngel.PWM.SetChannel( 3,PWMChannel[LEDPWM3]);
  CheckCloud();
 // ReefAngel.LCD.DrawText(0,255,95,120,PWMChannel[LEDPWM3]);
//Start of PWM slope function code designed for the PWM Expansion module
void PWMExpansion(byte cmd, byte data)
	Wire.beginTransmission(8); // transmit to device #2
	Wire.write('$'); // sends $
	Wire.write(cmd); // sends a value
	Wire.write(data); // sends 255
	Wire.endTransmission(); // stop transmitting
//End of PWM slope function code designed for the PWM Expansion module
void CheckCloud() {
 #define End_Cloud_Before NumMins(22,00)
#else
 #endif
 if (cloudchance)
 if (cloudchance)
 //delay(10);
 PWMChannel[b]=20;
 cloudindex++;
 int x=0;
 int x=0;
  cstart*=60;
  cend*=60;
Ok, some of this code was meant for a really old dimming module.
Try this:
 #define CUSTOM_MAIN
#define VersionMenu
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
byte PWMChannel[]={
  0,0,0,0,0,0};
//int cloudstart=0;
  //ATO status
  byte highcolor;
  //End ATO status
void setup() {
    //Port 1 = ATO
    //Port 3 = Heater
    if ( feeding == 0 )
  if ( feeding > 0 )
    feeding = 0;
   //#PWMEXPANSION
//Channel 0 = Blue
//Channel 1 = White
//Channel 2 = OCW
  CheckCloud();
  ReefAngel.PWM.SetChannel( LEDPWM0,PWMChannel[LEDPWM0]);
  ReefAngel.PWM.SetChannel( LEDPWM1,PWMChannel[LEDPWM1]);
  ReefAngel.PWM.SetChannel( LEDPWM2,PWMChannel[LEDPWM2]);
  ReefAngel.PWM.SetChannel( LEDPWM3,PWMChannel[LEDPWM3]);
void CheckCloud() {
#else
 #endif
 if (cloudchance)
 if (cloudchance)
 //delay(10);
 PWMChannel[b]=20;
 cloudindex++;
 int x=0;
 int x=0;
  cstart*=60;
  cend*=60;
dlplunkett44
IT WORKS!!! Thanks! I tried it out this morning. The only thing is that I feel like the lights should dim faster when a cloud happens. Is this the code that I should change?
I was thinking I would change it to
PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,30);
Would that make the dimming choppy though?
Cool!!!
Yes, I think you got it where to change for faster cloud :)
