ReefAngel Client V2.2
Does the "Feed Mode" in the Timers section control all devices specified in the "ReefAngel.FeedingModePorts" section of the .pde file?
Is the value specified in seconds?
Is there somewhere we specify the duration of the Water Change?
Client V2.2
Re: Client V2.2
Yes, in seconds and it is the timer that you see on the screen when you go into feeding mode using the joystick.
Correct, it turns off whatever you have specified on ReefAngel.FeedingModePorts.
Water change has no timer.
