PWM Dimming Expansion
clw143
Post by clw143 »
So if I add this to my code I can control from portal.
  ReefAngel.PWM.Channel2PWMParabola();
  ReefAngel.PWM.Channel3PWMParabola();
  ReefAngel.PWM.Channel4PWMParabola();
  ReefAngel.PWM.Channel5PWMParabola();
My best guess all these channels will be like the PWM Actinic channel was and my sunrise and sunset code will be the same for all of them. How do I tell it some of them are daylight and to use the actinic offset?
Re: PWM Dimming Expansion
You can give each of those lines an argument for their offset.
If you want to use the Actinic offset variable you can reference it with this function
ReefAngel.InternalMemory.ActinicOffset_read();
clw143
Post by clw143 »
lnevo wrote:ReefAngel.InternalMemory.ActinicOffset_read();
ReefAngel Class does not have InternalMemory.
You mean do this?
ReefAngel.PWM.Channel0PWMParabola(InternalMemory.ActinicOffset_read());
Yes. Exactly sorry for the mistake :)
clw143
Post by clw143 »
I don't suppose lights off overheat can apply like they did by port with standard lights?
It doesn't apply, but you can code your own thing.
Something like this:
if (ReefAngel.Params.Temp[T1_PROBE]>1200)
  ReefAngel.PWM.SetChannel(0,0);
clw143
Post by clw143 »
... make tartar sauce!
clw143
Post by clw143 »
I also suppose lights on and lights off will work anymore either with out extra code?
Lights On/Off only work for relay ports and standard dimming channels. They do not do anything to the dimming channels.
clw143
Post by clw143 »
Does something like this work?
  if ( (ReefAngel.Params.Temp[T1_PROBE]>InternalMemory.OverheatTemp_read()) || (ReefAngel.LightsOff=true) ) ReefAngel.PWM.SetChannel (0,0);
edit: guess not "(did you forget the '&' ?)"
There is no such thing as ReefAngel.LightsOff
The easiest way is to use the relay port in ReefAngel.LightsOnPort to assign a value to the channel.
This is what I do on mine:
  if ((ReefAngel.Relay.RelayMaskOn & (1<<(Radion1-1))) == (1<<(Radion1-1))) // If MaskOn, we override PWM to internal memory value
    ReefAngel.RF.SetChannel(Radion_White,InternalMemory.RadionSlopeEndW_read());
    ReefAngel.RF.SetChannel(Radion_RoyalBlue,InternalMemory.RadionSlopeEndRB_read());
    ReefAngel.RF.SetChannel(Radion_Red,InternalMemory.RadionSlopeEndR_read());
    ReefAngel.RF.SetChannel(Radion_Green,InternalMemory.RadionSlopeEndG_read());
    ReefAngel.RF.SetChannel(Radion_Blue,InternalMemory.RadionSlopeEndB_read());
    ReefAngel.RF.SetChannel(Radion_Intensity,InternalMemory.RadionSlopeEndI_read());
    ReefAngel.RF.ChannelWhiteSlope();
    ReefAngel.RF.ChannelRoyalBlueSlope();
    ReefAngel.RF.ChannelRedSlope();
    ReefAngel.RF.ChannelGreenSlope();
    ReefAngel.RF.ChannelBlueSlope();
    ReefAngel.RF.ChannelIntensitySlope();
clw143
Post by clw143 »
I don't suppose something like this will work?
ReefAngel.PWM.SetChannel (0&&1&&2&&3&&4&&5,0);
It does compile.
Mathematically, 0&&1&&2&&3&&4&&5 = 0
So, it is the same as this:
