Busy COM port
Posted: Thu Mar 27, 2014 6:10 am
by wolf8895
I was trying to upload some new code last night and kept getting an error that the COM port was busy. Has anyone else ever run into this? If so, how did you fix it?
I've tried rebooting both the laptop and the RA. I've also uninstalled and reinstalled the USB serial converter. Do I just need to reinstall the RA installer?
Re: Busy COM port
Posted: Thu Mar 27, 2014 8:48 am
Do you have the Reef Angel Client software installed in your computer?
Re: Busy COM port
Posted: Thu Mar 27, 2014 12:44 pm
by wolf8895
I do have the client suite installed. I'm pretty sure I killed that but I can uninstall it and try that later on tonight.
Re: Busy COM port
Posted: Thu Mar 27, 2014 1:15 pm
The Client is installed as a service. That's how it can keep pulling data from your controller and it uses the same port that you upload codes.
So, if you want to use the port, you need to stop the service and restart after you upload your code to restore functionality of the Client.
You can do this in the Services Dashboard that is installed along with the Client.
Re: Busy COM port
Posted: Thu Mar 27, 2014 8:00 pm
by wolf8895
That worked!! Thanks.
