what do you think of reset the controller if T1 is = 0 ?
lukeluke
Post by lukeluke »
What do you think ?
I have this problem... the T1 probe sometime read 0 .
For me this situation is much serious, because the fan and the heater don't work.
I have the optiboot.
Can i force the wdt reset or in the inizialization fase can have a problem ?
i think t put at the end of my pde this string :
if (ReefAngel.Params.Temp1 = 0) wdt_reset();
THANKS
Re: what do you think of reset the controller if T1 is = 0 ?
lukeluke wrote:What do you think ?
THANKS
that would not reset the controller. that would do the opposite and keep the watchdog from resetting.
your if statement will need 2 = in a row to check for equality.
if ( ReefAngel.Params.Temp1 == 0)  delay(500);
or something like that to allow the watchdog to reset. the main thing is the delay needs to be long enough to prevent the timer from being reset and then the controller will reboot.
lukeluke
Post by lukeluke »
if i put the delay to 500 the WD reset automatically the controller ?
make it a little longer, over 1000 should be fine.
