Time change
gallowy2
Time change
Post by gallowy2 »
How do I change the internal time in a reef angel? How unit thinks it is 5 hours ahead of the current time and 20 days behind. The is not a setup option when i use the joystick.
Re: Time change
Is that a standard RA?
Do you have wifi?
gallowy2
Re: Time change
Post by gallowy2 »
I do have the wifi
gallowy2
Re: Time change
Post by gallowy2 »
Thanks. I forgot I could login through the portal and fix it.
gallowy2
Re: Time change
Post by gallowy2 »
Why would the unit not keep the time? I have to reset the time again tonight.
Re: Time change
I had a loose contact on the battery holder
