I was wondering if someone who speaks code fluently
Thank You,
GC
Dan
byte ActinicPWMValue=0; // For cloud code
byte DaylightPWMValue=0; // For cloud code
InternalMemory.OverheatTemp_write( 810 );
void CheckCloud()
#define Clouds_Every_X_Days 2 // Frequency in days based on the day of the month - number 2 means every 2 days, for example (day 2,4,6 etc)
#define Cloud_Chance_per_Day 65 // Percentage chance of a cloud happening today
#define Min_Cloud_Duration 7 // Minimum number of minutes for cloud duration. Don't use max duration of less than 6
#define Max_Cloud_Duration 12 // Maximum number of minutes for the cloud duration. Don't use max duration of more than 255
#define Min_Clouds_per_Day 1 // Minimum number of clouds that can happen per day
#define Max_Clouds_per_Day 2 // Maximum number of clouds that can happen per day
#define Start_Cloud_After NumMins(12,00) // Only start the cloud effect after this setting - In this example, start cloud after noon
#define End_Cloud_Before NumMins(17,00) // Always end the cloud effect before this setting - In this example, end cloud before 9:00pm
#define Lightning_Change_per_Cloud 100 // Percentage chance of a lightning happen for every cloud - use 100 and cause the lightning to have 100% chance of happening
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen results could happen.
// Add Random Lightning modes
#define Calm 0 // No lightning
#define Slow 1 // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2 // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3 // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4 // Like Mega, but with more lightning
byte LightningModes[] = { Fast, Mega, Calm, Calm }; // Set which modes you want to use - Example:{ Slow, Fast, Mega, Mega2 } to randomize all four modes.
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
static byte lightningMode=0;
static time_t DelayCounter=millis(); // Variable for lightning timing.
static int DelayTime=random(1000); // Variable for lightning timimg.
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
randomSeed(millis()); // Seed the random number generator
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
if (chooseLightning)
chooseLightning=false;
switch (lightningMode)
case Calm:
break;
case Mega:
// Lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (int i=0; i<a; i++)
analogWrite(daylightPWMPin,random(DaylightPWMValue*2.55,255)); // Flash on
int randy=random(20,80); // Random number for a delay
if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay
delay(randy); // Wait from 20 to 69 ms, or 100-400 ms
analogWrite(daylightPWMPin,DaylightPWMValue*2.55); // Flash off
delay(random(30,50)); // Wait from 30 to 49 ms
wdt_reset();
DelayCounter=millis(); // If we just had a round of flashes, then lets put in a longer delay
DelayTime=random(1000); // of up to a second for dramatic effect before we do another round.
break;
case Mega2:
// Higher lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
if (lightningchance && random(ReversePWMSlope(cloudstart,cloudstart+cloudduration,100,0,180))<2 && (millis()-DelayCounter)>DelayTime)
wdt_reset();
break;
case Fast:
wdt_reset();
break;
case Slow:
// Slow lightning for 5 seconds in the middle of the cloud. Suitable for slower ELN style drivers
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
DaylightPWMValue=0;
delay(1);
break;
default:
break;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
else x=17;
else x=35;
ReefAngel.CustomVar[7]=(cloudduration); // Put the duration of the next cloud in a custom var for the portal
if (lightningchance)
int x=0;
else x=57;
ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60; // Write the hour of the next lightning to a custom variable for the Portal
else x=75;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
ReefAngel.StandardLights( Port1,17,0,17,2 ); // Top Off Pump
ReefAngel.StandardLights( Port2,19,0,19,1 ); // Drain Pump
ReefAngel.StandardLights( Port3,19,2,19,5 ); // Fill Pump
ReefAngel.StandardHeater( Port4,771,776 ); // Heater, Duh.
ReefAngel.StandardFan( Port5,781,785 ); // Fan, Duh.
ReefAngel.StandardLights( Port6,9,0,20,0 ); // Big Lights
ReefAngel.StandardLights( Port7,8,29,20,31 ); // LED Fans
ReefAngel.StandardLights( Port8,8,28,20,32 ); // LED Power Supply
//Lighting Control
ActinicPWMValue=PWMSlope(8,30,20,30,0,90,60,ActinicPWMValue);
DaylightPWMValue=PWMSlope(9,0,20,0,0,90,45,DaylightPWMValue);
CheckCloud();
if (hour()>=9 && hour()<17)
pinMode(lowATOPin,OUTPUT);
analogWrite(lowATOPin,LongPulseMode(31,60,8,true)*2.55);
pinMode(highATOPin, OUTPUT);
analogWrite(highATOPin,LongPulseMode(31,60,8,false)*2.55);
else if (hour()>=17 && hour()<18)
analogWrite(lowATOPin, NutrientTransportMode(32,75,500,true)*2.55);
pinMode(highATOPin,OUTPUT);
analogWrite(highATOPin, NutrientTransportMode(32,75,500,false)*2.55);
else if (hour()>=18 && hour()<9)
analogWrite(lowATOPin,LongPulseMode(32,40,12,true)*2.55);
analogWrite(highATOPin,LongPulseMode(32,40,12,false)*2.55);
ReefAngel.Portal( "GiraffeCat" , "passwordgoeshere" );
