i have been noticing the my wifi would not response to a ping nor update my iPhone app.
the only way to revive the Wifi is disconnect the connector. is there any API that sets auto turn off?
i did check the sleep API and that is set to 0
Arnee.
Wifi Module status lights are off after a few days.
Re: Wifi Module status lights are off after a few days.
You mean that even the green LED doesn't blink?
yup, no lights. i measured the input voltage while Wifi is plug in and that seems to be with in spec. i just open my iPhone app and its not responding at all. call my wife at home and she said no lights are on..
i also notice that the blue wire (from the wifi cable to the controller) does not have any voltage when all lights are off, it reads 3.2volts when it up and running.
I'm going to bump this because I am having the same issue.
Works fine, then randomly I lose connection (time working has ranged from over 24 hours to under 2), and when it's not working, all lights are off on the adapter. I am posting here since most other issues around wifi seem to still have some activity from the adapter.
Updated to the newest firmware, newest client, newest android app and do not have the desktop sidebar thing installed.
