Clouds/Lightning/Storms for 16 Channel PWM Expansion
dlplunkett44
Post by dlplunkett44 »
I recently purchased the 16 channel PWM expansion, but I am having trouble understanding how to code for it. I would like to have clouds and lightning like the topic says. I will have reds, greens, UV, on their own channels, but I will have several channels for whites and blues, for different areas of the tank (east to west). I would like to have clouds come in and move from side to side with chances for lightning. I would also like to have a few channels for the moonlights so the moon can move from side to side as well, and simulate different moon stages. Finally, I would also like to have the option of manually starting a cloud with and without lightning manually.
I am not sure where to even begin though as I do not even know how to program for the 16 channel expansion at all. I would absolutely want to keep the 12 bit resolution that the expansion is capable of though too.
For people that have the 16 channel expansion, could you post some examples of how you have yours programmed?
AlanM
Re: Clouds/Lightning/Storms for 16 Channel PWM Expansion
Post by AlanM »
Colin has cloud code that he has been working on at http://forum.reefangel.com/viewtopic.php?f=12&t=4783
I added some functions to the development branch to integrate the 16 channel PWM in to the libries and made sure that it was compatible with the cloud/lightning stuff that Colin was doing. Have you pulled down the development branch of the reefangel code and tried using that?
You'd go to
https://github.com/reefangel/Libraries/tree/dev
and click "Download Zip" and unzip that into your Libraries directory.
then go to
https://github.com/reefangel/FeaturesAndUpdateFiles
and get download the zip there as well and put the feature.txt file into the "update" folder of the Reef Angel arduino directory and you can start using the 16 channel dimming by adding the line:
ReefAngel.Add16ChPWM();
into your .ino file.
Once you have that, you can address those channels the same as the regular dimming ones. If you want to do some of the east to west stuff and the manual stuff you'll be doing some custom stuff so you'll likely need to understand what Colin's code is doing and how to change it to do what you want.
You can look at my .ino to see how I'm sending dimming levels to the 16 channel PWM using the dev version of the libraries here: http://forum.reefangel.com/viewtopic.php?f=11&t=4806
dlplunkett44
I am working on adapting code for this but I have a question...
What would be the equivalent for this:
analogWrite(daylightPWMPin,random(DaylightPWMValue*2.55,255));
How do I "analogWrite to the pins on the 16 channel expansion?
This is how to talk to the chip directly:
    int newdata=4095;
    byte channel=0;
    Wire.beginTransmission(0x41);
    Wire.write(0x8+(4*channel));
    Wire.write(newdata&0xff);
    Wire.write(newdata>>8);
    Wire.endTransmission();
newdata can be any 12bit value, which means from 0 to 4095.
channel can be any of the 16 channels from 0 to 15
Without having a way to test it, I think something like this should work.
Replace this:
With this:
int newdata=random(DaylightPWMValue*40.95, 4095);
    byte channel=0;
dlplunkett44
Ok, does this code seem ok? I still have several things I need to work out: clouds moving from side to side, moon phases and seasons. Other than those things, does this seem like it will work for generating clouds/lightning? THANKS!!
ReefAngel.Init();
//Initialize controller
 ReefAngel.Use2014Screen();
// Let's use 2014 Screen
ReefAngel.AddPHExpansion();
// pH Expansion Module
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port1Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
ReefAngel.Relay.On( Port4 );
// Add support for 16 channel PWM board
ReefAngel.SingleATO( true,Port1,90,0 );
ReefAngel.StandardHeater( Port2,820,825 );
ReefAngel.StandardHeater( Port3,815,823 );
ReefAngel.WavemakerRandom( Port5,25,45 );
ReefAngel.WavemakerRandom( Port6,25,45 );
ReefAngel.StandardLights( Port7,21,0,7,0 );
ReefAngel.CO2Control( Port8,670,675 );
ReefAngel.DosingPumpRepeat( Box1_Port1,0,60,10 );
//0 = White Far East
PWMChannel[0]=PWMParabola(8,0,20,30,0,80,0);
//1 = White Near East
PWMChannel[1]=PWMParabola(8,5,20,35,0,80,0);
//2 = White Near West
PWMChannel[2]=PWMParabola(8,10,20,40,0,80,0);
//3 = White Far West
PWMChannel[3]=PWMParabola(8,15,20,45,0,80,0);
//4 = Blue Far East
PWMChannel[4]=PWMParabola(7,15,21,15,0,80,0);
//5 = Blue Near East
PWMChannel[5]=PWMParabola(7,20,21,20,0,80,0);
//6 = Blue Near West
PWMChannel[6]=PWMParabola(7,25,21,25,0,80,0);
//7 = Blue Far West
PWMChannel[7]=PWMParabola(7,30,21,30,0,80,0);
//8 = OCW Far East
PWMChannel[8]=PWMParabola(8,15,20,15,0,60,0);
//9 = OCW Near East
PWMChannel[9]=PWMParabola(8,20,20,20,0,60,0);
//10 = OCW Near West
PWMChannel[10]=PWMParabola(8,25,20,25,0,60,0);
//11 = OCW Far West
PWMChannel[11]=PWMParabola(8,30,20,30,0,60,0);
//12 = Violets
PWMChannel[12]=PWMParabola(8,15,20,30,0,65,0);
//13 = Moonlight Far East
PWMChannel[13]=PWMParabola(20,15,8,30,0,15,0);
//14 = Moonlight Near East and West
PWMChannel[14]=PWMParabola(20,20,8,35,0,15,0);
//15 = Moonlight Far West
PWMChannel[15]=PWMParabola(20,25,8,40,0,15,0);
CheckCloud();
ReefAngel.PWM.SetChannel(0,PWMChannel[0]);
ReefAngel.PWM.SetChannel(1,PWMChannel[1]);
ReefAngel.PWM.SetChannel(2,PWMChannel[2]);
ReefAngel.PWM.SetChannel(3,PWMChannel[3]);
ReefAngel.PWM.SetChannel(3,PWMChannel[4]);
ReefAngel.PWM.SetChannel(3,PWMChannel[5]);
ReefAngel.PWM.SetChannel(3,PWMChannel[6]);
ReefAngel.PWM.SetChannel(3,PWMChannel[7]);
ReefAngel.PWM.SetChannel(3,PWMChannel[8]);
ReefAngel.PWM.SetChannel(3,PWMChannel[9]);
ReefAngel.PWM.SetChannel(3,PWMChannel[10]);
ReefAngel.PWM.SetChannel(3,PWMChannel[11]);
ReefAngel.PWM.SetChannel(3,PWMChannel[12]);
ReefAngel.PWM.SetChannel(3,PWMChannel[13]);
ReefAngel.PWM.SetChannel(3,PWMChannel[14]);
ReefAngel.PWM.SetChannel(3,PWMChannel[15]);
ReefAngel.AddWifi();
void CheckCloud()
#define Clouds_Every_X_Days 1
 // Minimum number of minutes for cloud duration. Don't use min duration of less than 6
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 7
 // In this example, start could after 8:30am
#define Start_Cloud_After NumMins(08,30)
 // In this example, end could before 7:00pm
#define End_Cloud_Before NumMins(19,00)
#define Lightning_Change_per_Cloud 70
#define Actinic_Channels B0000010000000000
#define Daylight_Channels B0000100000000000
    // Add Random Lightning modes
  // Example:  { Slow, Fast, Mega, Mega2 } to randomize all four modes.
  byte LightningModes[] = { Mega, Mega, Mega2, Calm, Calm, Fast };
 static byte cloudchance=255;
 static byte cloudduration=0;
 static int cloudstart=0;
 static byte numclouds=0;
 static byte cloudindex=0;
 static int LastNumMins=0;
 static byte lightningMode=0;
#ifdef forcecloudcalculation
 if (cloudchance==255)
#else
#endif
 cloudchance=random(100);
 // If we have cloud today
 if (cloudchance)
 lightningchance=random(100);
 if (cloudchance)
 	//is it time for cloud yet?
 		for (int a=0;a<16;a++)
 				// this will slope down the DAYLIGHT channels from the current PWM to 0 within 3 minutes.
 				PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
int newdata=4095;
byte channel=0;
if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
          int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
          for (int i=0; i<a; i++)
		for (int g=0;g<16;g++)
		if (bitRead(Daylight_Channels,g)==1)
    		channel=g;
 		for (int h=0;h<16;h++)
		if (bitRead(Daylight_Channels,h)==1)
		newdata=DaylightPWMValue*40.95;
    		channel=h;
            wdt_reset();
        break;
      case Mega2:
        if (lightningchance && random(ReversePWMSlope(cloudstart,cloudstart+cloudduration,100,0,180))<2 && (millis()-DelayCounter)>DelayTime)
		for (int k=0;k<16;k++)
		if (bitRead(Daylight_Channels,k)==1)
    		channel=k;
		for (int l=0;l<16;l++)
		if (bitRead(Daylight_Channels,l)==1)
    		channel=l;
            wdt_reset();
        break;
      case Fast:
            for (int e=0;e<16;e++)
		if (bitRead(Daylight_Channels,e)==1)
    		channel=e;
	    for (int f=0;f<16;f++)
		if (bitRead(Daylight_Channels,f)==1)
    		channel=f;
            wdt_reset();
        break;
      case Slow:
          else lightningstatus=0;
          if (lightningstatus)
            newdata=4095;
		for (int c=0;c<16;c++)
		if (bitRead(Daylight_Channels,c)==1)
			channel=c;
		newdata=0;
		for (int d=0;d<16;d++)
		if (bitRead(Daylight_Channels,d)==1)
			channel=d;
          delay(1);
        break;
      default:
        break;
 		cloudindex++;
 		if (cloudindex < numclouds)
  // Write the times of the next cloud, next lightning, and cloud duration to the screen.
 		int x=0;
		else x=17;
		else x=35;
 if (lightningchance)
 int x=0;
 else x=57;
 else x=75;
 cstart*=60;
 cend*=60;
 if (n>cend) return PWMStart;
I think it looks good.
Did you try it out? :)
dlplunkett44
So it won't compile. These are the errors that it gives me:
It stops on 'class ReefAngelClass' has no member named 'Add16ChPWM'
Then these are the errors below:
Watchdog Timer
Version Menu
16 Channel Dimming Expansion Module
Dimming Signal
Wifi Attachment
Relay Expansion Module
2014 Main Screen
pH Expansion Module
Number of Relay Expansion Modules: 1
Simple Menu
In_Progress.cpp:422:20: error: invalid digit "8" in octal constant
In_Progress.cpp:422:38: error: invalid digit "8" in octal constant
In_Progress.cpp:422:75: error: invalid digit "8" in octal constant
In_Progress.cpp:676:29: error: invalid digit "8" in octal constant
In_Progress.cpp:676:67: error: invalid digit "8" in octal constant
In_Progress.cpp:676:116: error: invalid digit "8" in octal constant
In_Progress.cpp:676:154: error: invalid digit "8" in octal constant
In_Progress.cpp:676:222: error: invalid digit "8" in octal constant
In_Progress.cpp: In function 'void setup()':
In_Progress:150: error: 'class ReefAngelClass' has no member named 'Add16ChPWM'
In_Progress.cpp: In function 'void loop()':
In_Progress:221: error: 'PWMChannel' was not declared in this scope
In_Progress:258: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:259: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:260: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:261: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:262: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:263: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:264: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:265: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:266: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:267: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:268: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:269: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:270: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:271: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:272: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:273: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress.cpp: In function 'void CheckCloud()':
In_Progress:437: error: 'B0000010000000000' was not declared in this scope
In_Progress:443: error: 'PWMChannel' was not declared in this scope
In_Progress:474: error: 'B0000100000000000' was not declared in this scope
In_Progress:476: error: 'DaylightPWMValue' was not declared in this scope
In_Progress:493: error: 'B0000100000000000' was not declared in this scope
In_Progress:495: error: 'DaylightPWMValue' was not declared in this scope
In_Progress:524: error: 'B0000100000000000' was not declared in this scope
In_Progress:526: error: 'DaylightPWMValue' was not declared in this scope
In_Progress:542: error: 'B0000100000000000' was not declared in this scope
In_Progress:544: error: 'DaylightPWMValue' was not declared in this scope
In_Progress:561: error: jump to case label
In_Progress:516: error: crosses initialization of 'int a'
In_Progress:572: error: 'B0000100000000000' was not declared in this scope
In_Progress:574: error: 'DaylightPWMValue' was not declared in this scope
In_Progress:590: error: 'B0000100000000000' was not declared in this scope
In_Progress:592: error: 'DaylightPWMValue' was not declared in this scope
In_Progress:609: error: jump to case label
In_Progress:620: error: 'B0000100000000000' was not declared in this scope
In_Progress:638: error: 'B0000100000000000' was not declared in this scope
In_Progress:653: error: jump to case label
In_Progress:657: error: expected `}' before 'else'
Reef Angel Libraries Found: Development
Reef Angel Libraries Version: 1.1.0
Did you download the latest dev libraries?
dlplunkett44
Yes, I put the dev libraries in the libraries folder, but I had to rename the folder from "Libraries-dev" to Librariesdev. Arduino didn't like the "-" I guess. I also put the feature and source files in the update folder, overwriting the old version.
Ok, so I know that this is wrong 'B0000010000000000'
You need to convert that to decimal. Arduino doesn't have that declared internally.
So, binary 0000010000000000 = decimal 1024
Also, you should actually rename your original libraries folder to something like libraries-original and you need to rename the libraries-dev to libraries.
The contents of libraries is what Arduino will be looking at.
dlplunkett44
Ok, so I renamed my original library to librariesoriginal and the dev libraries to "libraries". I'm still getting the same errors. Also, the binary numbers were copied from someone else's lightning code that I've been using for quite a while. It was for the 6 channel PWM expansion, so I added 10 digits. Could this be why? How could I get the binary number to work? The code does a bit read to determine if a particular channel is to be flashed or not.
dlplunkett44
I got rid of the binary problem by adding word in front of the number so
became
#define word Actinic_Channels B0000010000000000
This is now my error log:
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
2014 Main Screen
pH Expansion Module
Simple Menu
In_Progress:147: error: 'class ReefAngelClass' has no member named 'Add16ChPWM'
In_Progress:196: error: 'PWMChannel' was not declared in this scope
In_Progress:233: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:234: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:235: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:236: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:237: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:238: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:239: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:240: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:241: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:242: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:243: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:244: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:245: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:246: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:247: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:248: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:412: error: 'Actinic_Channels' was not declared in this scope
In_Progress:418: error: 'PWMChannel' was not declared in this scope
In_Progress:449: error: 'Daylight_Channels' was not declared in this scope
In_Progress:451: error: 'DaylightPWMValue' was not declared in this scope
In_Progress:453: error: 'Wire' was not declared in this scope
In_Progress:468: error: 'Daylight_Channels' was not declared in this scope
In_Progress:470: error: 'DaylightPWMValue' was not declared in this scope
In_Progress:472: error: 'Wire' was not declared in this scope
In_Progress:499: error: 'Daylight_Channels' was not declared in this scope
In_Progress:501: error: 'DaylightPWMValue' was not declared in this scope
In_Progress:503: error: 'Wire' was not declared in this scope
In_Progress:517: error: 'Daylight_Channels' was not declared in this scope
In_Progress:519: error: 'DaylightPWMValue' was not declared in this scope
In_Progress:521: error: 'Wire' was not declared in this scope
In_Progress:536: error: jump to case label
In_Progress:491: error: crosses initialization of 'int a'
In_Progress:547: error: 'Daylight_Channels' was not declared in this scope
In_Progress:549: error: 'DaylightPWMValue' was not declared in this scope
In_Progress:551: error: 'Wire' was not declared in this scope
In_Progress:565: error: 'Daylight_Channels' was not declared in this scope
In_Progress:567: error: 'DaylightPWMValue' was not declared in this scope
In_Progress:569: error: 'Wire' was not declared in this scope
In_Progress:584: error: jump to case label
In_Progress:595: error: 'Daylight_Channels' was not declared in this scope
In_Progress:598: error: 'Wire' was not declared in this scope
In_Progress:613: error: 'Daylight_Channels' was not declared in this scope
In_Progress:616: error: 'Wire' was not declared in this scope
In_Progress:628: error: jump to case label
In_Progress:632: error: expected `}' before 'else'
Thanks again.
There are several things I found wrong:
You must declare variables you are using above loop.
int PWMChannel[16];
int DaylightPWMValue;
You can't use this:
You must enter the number of minutes yourself instead of a formula. 510 and 1140 respectively.
We are using a define statement instead of a variable.
If you declare that as a variable above setup(), you could use a formula, but that just complicates everything. Just use the numbers.
The 16 channel uses a different function.
Change SetChannel to Set16Channel.
There is something wrong with the Mega2 section of your code. I removed it and was able to compile. I think there is an extra or missing bracket somewhere.
Ahh.. The binary can't be used like that.
You must represent it as a decimal or hex number.
Just use a calculator to convert. I already showed the conversion to decimal of one of them in the previous post.
dlplunkett44
I'm still getting all the same errors. I think its not taking the dev libraries correctly.
dlplunkett44
OK, so I uninstalled reefangel, reinstalled, and redid the dev libraries and these are the errors I'm getting now:
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
2014 Main Screen
pH Expansion Module
Simple Menu
In_Progress.cpp:400:20: error: invalid digit "8" in octal constant
In_Progress.cpp:400:38: error: invalid digit "8" in octal constant
In_Progress.cpp:400:75: error: invalid digit "8" in octal constant
In_Progress.cpp:654:29: error: invalid digit "8" in octal constant
In_Progress.cpp:654:67: error: invalid digit "8" in octal constant
In_Progress.cpp:654:116: error: invalid digit "8" in octal constant
In_Progress.cpp:654:154: error: invalid digit "8" in octal constant
In_Progress.cpp:654:222: error: invalid digit "8" in octal constant
In_Progress:199: error: 'PWMChannel' was not declared in this scope
In_Progress:249: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:250: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:251: error: 'class RA_PWMClass' has no member named 'SetChannel'
In_Progress:322: error: expected initializer before numeric constant
In_Progress:415: error: 'Actinic_Channels' was not declared in this scope
In_Progress:421: error: 'PWMChannel' was not declared in this scope
In_Progress:433: error: 'LightningModes' was not declared in this scope
In_Progress:452: error: 'Daylight_Channels' was not declared in this scope
In_Progress:454: error: 'DaylightPWMValue' was not declared in this scope
In_Progress:456: error: 'Wire' was not declared in this scope
In_Progress:471: error: 'Daylight_Channels' was not declared in this scope
In_Progress:473: error: 'DaylightPWMValue' was not declared in this scope
In_Progress:475: error: 'Wire' was not declared in this scope
In_Progress:502: error: 'Daylight_Channels' was not declared in this scope
In_Progress:504: error: 'DaylightPWMValue' was not declared in this scope
In_Progress:506: error: 'Wire' was not declared in this scope
In_Progress:520: error: 'Daylight_Channels' was not declared in this scope
In_Progress:522: error: 'DaylightPWMValue' was not declared in this scope
In_Progress:524: error: 'Wire' was not declared in this scope
In_Progress:539: error: jump to case label
In_Progress:494: error: crosses initialization of 'int a'
In_Progress:550: error: 'Daylight_Channels' was not declared in this scope
In_Progress:552: error: 'DaylightPWMValue' was not declared in this scope
In_Progress:554: error: 'Wire' was not declared in this scope
In_Progress:568: error: 'Daylight_Channels' was not declared in this scope
In_Progress:570: error: 'DaylightPWMValue' was not declared in this scope
In_Progress:572: error: 'Wire' was not declared in this scope
In_Progress:587: error: jump to case label
In_Progress:598: error: 'Daylight_Channels' was not declared in this scope
In_Progress:601: error: 'Wire' was not declared in this scope
In_Progress:616: error: 'Daylight_Channels' was not declared in this scope
In_Progress:619: error: 'Wire' was not declared in this scope
In_Progress:631: error: jump to case label
In_Progress:635: error: expected `}' before 'else'
Were you not getting these errors when you compiled?
Thanks again.
ReefAngel.Init();
int PWMChannel[16];
//4 = Blue Far East
//7 = Blue Far West
//8 = OCW Far East
//9 = OCW Near East
//11 = OCW Far West
//12 = Violets
CheckCloud();
void CheckCloud()
int Actinic_Channels 0b0000010000000000
int Daylight_Channels 0b0000100000000000
#else
#endif
 if (cloudchance)
 if (cloudchance)
int newdata=4095;
byte channel=0;
      case Calm:
        break;
      case Mega:
          channel=g;
          channel=h;
            wdt_reset();
        break;
      case Mega2:
          channel=k;
          channel=l;
            wdt_reset();
        break;
      case Fast:
          channel=e;
          channel=f;
            wdt_reset();
        break;
      case Slow:
            newdata=4095;
         channel=c;
      newdata=0;
         channel=d;
          delay(1);
        break;
      default:
        break;
       cloudindex++;
       int x=0;
      else x=17;
      else x=35;
 int x=0;
 else x=57;
 else x=75;
 cstart*=60;
 cend*=60;
Which libraries folder are you replacing? What is the full path?
There's one thats for the arduino app/executables and another for the ra libraries.
I was, but I mentioned already what I did to fix the problem a couple posts above.
dlplunkett44
I replaced the libraries folder in my documents and in program files/reefangel.
Not that.
You need to declare the undeclared variables, you need to change the 16 bit binary number to a decimal and several other things I already mentioned throughout the post.
Please read back the previous posts and make those changes.
dlplunkett44
I did the undeclared variables (unless I put them in the wrong place) as for the decimal thing I'm not understanding. Is that because it is 16 bits? The original code was written that way. You can see my updated code a couple posts back.
Arduino libraries only have declarations for 8 bit binary numbers.
So, if you are trying to use 16bit, you must declare it as decimal or hexadecimal instead of binary.
Just use a calculator or online conversion like this: http://acc6.its.brooklyn.cuny.edu/~gurw ... 2tool.html
dlplunkett44
Ok, I understand why now.
I am still getting all the same errors though.
I changed the
#define Actinic_Channels B0000111100000000
and
#define Daylight_Channels B1111000000000000
to
#define Actinic_Channels 384
and
#define Daylight_Channels 61440
I also have
int PWMChannel[16];
in void setup
Could you explain the NumMins thing? That also was copied from the original code. Sorry, it just helps me to understand why things are being done and what they're doing.
The variable declarations can't be in setup()
It has to be above it or it will only be usable inside setup()
Since you are using them globally, you must declare them globally, which is above setup()
You can't use a function when you are declaring something as a #declare.
#declare is nothing more than an alias.
The compiler goes and changes every reference you have of the #declare to the number you declared. So, you can't use a function.
The exception is if you #declare it as a function too.
So, you either have to use this:
#declare Start_Cloud_After 510
Or like this:
#define Start_Cloud_After(h,m) NumMins(h,m)
And when you call it, you must call it like this:
Start_Cloud_After(8,30)
Which just complicates things to read. Just use the first option. Much easier to read. Why complicate when it is so simple, right?
dlplunkett44
OK, thanks for all your help! I got it to finally compile. Now its time to work on the other features.
dlplunkett44
So now I'm trying to make the clouds start in the east and move to the west. I think I have it set up right. It compiles ok, but does this look like it will do what I'm trying to get it to do?
If this looks good, then I'm going to have it randomly choose to start in the east or west.
This is just the section I changed. I also of course declared my variables above like this:
static time_t DelayCount=millis();
static int DelayTiming1=2000;
static int DelayTiming2=4000;
static int DelayTiming3=6000;
        //dim down the far east channels
        PWMChannel[0]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[0],0,60);
        PWMChannel[8]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[8],0,60);
        //delay 2 seconds before starting next dimming
        DelayTiming1=2000;
        if((millis()-DelayCount)>DelayTiming1)
        //dim down the near east channels
        PWMChannel[1]=ReversePWMSlope(cloudstart,cloudstart+cloudduration+DelayTiming1,PWMChannel[1],0,60);
        PWMChannel[9]=ReversePWMSlope(cloudstart,cloudstart+cloudduration+DelayTiming1,PWMChannel[9],0,60);
        DelayTiming2=4000;
        if((millis()-DelayCount)>DelayTiming2)
        //dim down the near west channels
        PWMChannel[2]=ReversePWMSlope(cloudstart,cloudstart+cloudduration+DelayTiming2,PWMChannel[2],0,60);
        PWMChannel[10]=ReversePWMSlope(cloudstart,cloudstart+cloudduration+DelayTiming2,PWMChannel[10],0,60);
        DelayTiming3=6000;
        if((millis()-DelayCount)>DelayTiming3)
        //dim down the far west channels
        PWMChannel[3]=ReversePWMSlope(cloudstart,cloudstart+cloudduration+DelayTiming3,PWMChannel[3],0,60);
        PWMChannel[11]=ReversePWMSlope(cloudstart,cloudstart+cloudduration+DelayTiming3,PWMChannel[11],0,60);
////////                          replacing this with above                         ////////
             // this will slope down the DAYLIGHT channels from the current PWM to 0 within 1 minutes.
             // and finally slope up from 0 to PWM value within 1 minutes
             PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,60);
This will never work:
You are basically assigning DelayCount=millis(); and right after you are checking if the difference in time is > than your DelayTiming1. It will never happen.
You have to assign DelayCount when the cloud starts and not all the time.
dlplunkett44
Oh yeah, I see that now, but I'm not sure exactly where to place it... Would this be right?
 if (cloudchance)
dlplunkett44
...or maybe its not needed there at all. I have it declared above at the beginning of checkcloud():
