How long will this power two WP-40's?
What are the dimensions of the charger, and approximately how long to fully charge?
Jebao Battery Backup Specs
Re: Jebao Battery Backup Specs
The charger is a sunforce solar panel: http://www.sunforceproducts.com/product ... UCT_ID=145
The battery can be changed to even a car battery if you would like. It comes with a cable with alligator clips that can be easily connected to the car battery.
The battery that the unit comes with is a very small battery (1.2Ah battery), which should hold for a couple hours.
You can also charge the battery with any car battery trickle charger instead of the solar panel for faster charge.
Thanks, Roberto.
I had a 7 hour power outage the other day while I was at work. Luckily, no losses. I'd like to not push my luck again.
