DosingPumpRepeat and actually time dosing pumps run...???
DavidinGA
Post by DavidinGA »
I'm curious as to how much 2 part I'm actually dosing using the RA DosingPumpRepeat command as it's set to run every so many hours each day. I think it's running an additional time each day at midnight; could someone confirm that?
For example here is my calcium dosing:
ReefAngel.DosingPumpRepeat( Port8,0,300,22 ); ////cal 300min = 5hrs 82.5ml day
So every 5 hours it doses for 22 seconds. So - 5am, 10am, 3pm, 8pm, and midnight? or 1am?
I assume it resets somehow for each day and doesn't go past dosing at midnight (otherwise the dosing pumps would always dose at different times each day if the hours carried over to the next day ~1am); right?
So will any hours set that would be after midnight for the day simply dose at midnight?
I'm trying to figure out how much I'm really dosing per 24 hours.
I've attached my full code and the ml amounts dosed (my dosing pumps dose 0.75ml per sec) if the pumps do all run at midnight to finish the days cycle if any hours would be past midnight.
Hopefully that all makes sense.
    InternalMemory.OverheatTemp_write( 845 );
    ReefAngel.StandardHeater( Port1,795,800 );  ////2 Heaters
    ReefAngel.StandardLights( Port3,24,0,15,0 );   ////scrubber lights 12am-3pm  15hrs on 9off
    ReefAngel.StandardLights( Port5,19,0,23,0 ); ////Metal Halide 7pm to 11pm
    ReefAngel.DosingPumpRepeat( Port6,0,660,10 ); /////mag 720min = 11hrs  15ml day
    ReefAngel.DosingPumpRepeat( Port7,0,360,25 );  /////alk 360min = 6hrs  75ml day
    ReefAngel.DosingPumpRepeat( Port8,0,300,22 );  ////cal 300min = 5hrs   82.5ml day 3cups per gal
    ReefAngel.DCPump.SetMode( LongPulse,60,10 );
    if (hour()<8)
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
else if (hour()==8 && minute()<4)
ReefAngel.DCPump.SetMode( LongPulse,85,20);
else if (hour()>=8 && hour()<10)
ReefAngel.DCPump.SetMode( ShortPulse,75,40 );
else if (hour()>=10 && hour()<12)
ReefAngel.DCPump.SetMode( LongPulse,85,4 );
else if (hour()>=12 && hour()<14)
ReefAngel.DCPump.SetMode( ReefCrest,56,20 );
else if (hour()>=14 && hour()<16)
ReefAngel.DCPump.SetMode( LongPulse,80,5 );
else if (hour()>=16 && hour()<22)
ReefAngel.DCPump.SetMode( LongPulse,70,14 );
else if (hour()==23 && minute()<4)
ReefAngel.DCPump.SetMode( LongPulse,90,5);
   ReefAngel.AddWifi();
if (ReefAngel.Relay.Status(Port5))
  ReefAngel.StandardFan(Port4,813,820);
  ReefAngel.Relay.Off(Port4);
if ((hour()>=14 && hour()<19) || (hour()>=23)) ReefAngel.Relay.On(Port2);
  else ReefAngel.Relay.Off(Port2);
    ReefAngel.Portal( "davidinga" );
    int x,y;
    // pH Expansion
    ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,66, 100 );
Re: DosingPumpRepeat and actually time dosing pumps run...??
It will not dose a midnight, but it will reset every midnight.
So, for your schedule, you are only getting 4 doses.
Sorry, my bad.
You are correct.
It does dose at midnight.... So you are getting 5 doses.
DavidinGA
Post by DavidinGA »
rimai wrote:Sorry, my bad.
You are correct.
So...
This will actually dose 3 times per 24 hour cycle?
This will only dose exactly what it says since it ends on hour 24?
And this will dose 5 times like you said.
Correct.
Here is the math behind it:
	signed long t=(elapsedSecsToday(now())-((long)OffsetMinute*60));
	Relay.Set(DPRelay,(t%((long)RepeatMinute*60))<RunTime && t>=0);
It basically gets the number of seconds today, which starts at midnight, and uses modulo to find out the residual of the division.
If the residual is less than runtime, it turns on the relay.
DavidinGA
Post by DavidinGA »
Ok.
