DosingPumpRepeat and actually time dosing pumps run...???
Posted: Sat Oct 25, 2014 9:10 am
I'm curious as to how much 2 part I'm actually dosing using the RA DosingPumpRepeat command as it's set to run every so many hours each day. I think it's running an additional time each day at midnight; could someone confirm that?
For example here is my calcium dosing:
ReefAngel.DosingPumpRepeat( Port8,0,300,22 ); ////cal 300min = 5hrs 82.5ml day
So every 5 hours it doses for 22 seconds. So - 5am, 10am, 3pm, 8pm, and midnight? or 1am?
I assume it resets somehow for each day and doesn't go past dosing at midnight (otherwise the dosing pumps would always dose at different times each day if the hours carried over to the next day ~1am); right?
So will any hours set that would be after midnight for the day simply dose at midnight?
I'm trying to figure out how much I'm really dosing per 24 hours.
I've attached my full code and the ml amounts dosed (my dosing pumps dose 0.75ml per sec) if the pumps do all run at midnight to finish the days cycle if any hours would be past midnight.
Hopefully that all makes sense.
InternalMemory.OverheatTemp_write( 845 );
ReefAngel.StandardHeater( Port1,795,800 ); ////2 Heaters
ReefAngel.StandardLights( Port3,24,0,15,0 ); ////scrubber lights 12am-3pm 15hrs on 9off
ReefAngel.StandardLights( Port5,19,0,23,0 ); ////Metal Halide 7pm to 11pm
ReefAngel.DosingPumpRepeat( Port6,0,660,10 ); /////mag 720min = 11hrs 15ml day
ReefAngel.DosingPumpRepeat( Port7,0,360,25 ); /////alk 360min = 6hrs 75ml day
ReefAngel.DosingPumpRepeat( Port8,0,300,22 ); ////cal 300min = 5hrs 82.5ml day 3cups per gal
ReefAngel.DCPump.SetMode( LongPulse,60,10 );
if (hour()<8)
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
else if (hour()==8 && minute()<4)
ReefAngel.DCPump.SetMode( LongPulse,85,20);
else if (hour()>=8 && hour()<10)
ReefAngel.DCPump.SetMode( ShortPulse,75,40 );
else if (hour()>=10 && hour()<12)
ReefAngel.DCPump.SetMode( LongPulse,85,4 );
else if (hour()>=12 && hour()<14)
ReefAngel.DCPump.SetMode( ReefCrest,56,20 );
else if (hour()>=14 && hour()<16)
ReefAngel.DCPump.SetMode( LongPulse,80,5 );
else if (hour()>=16 && hour()<22)
ReefAngel.DCPump.SetMode( LongPulse,70,14 );
else if (hour()==23 && minute()<4)
ReefAngel.DCPump.SetMode( LongPulse,90,5);
ReefAngel.AddWifi();
if (ReefAngel.Relay.Status(Port5))
ReefAngel.StandardFan(Port4,813,820);
ReefAngel.Relay.Off(Port4);
if ((hour()>=14 && hour()<19) || (hour()>=23)) ReefAngel.Relay.On(Port2);
else ReefAngel.Relay.Off(Port2);
ReefAngel.Portal( "davidinga" );
int x,y;
// Parameters
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,66, "PHE:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,66, 100 );
// Main Relay Box
// Date and Time
