Need help (first time set-up)
I followed all the steps and when I try to load it to the controller, I get sketh to big error message.
Here is my sketch:
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port6Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit | Port6Bit | Port7Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port2Bit | Port4Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardLights( Port4,18,0,9,0 );
ReefAngel.CO2Control( Port7,830,800 );
ReefAngel.MHLights( Box1_Port2,10,0,17,0,2 );
ReefAngel.MHLights( Box1_Port4,10,0,17,0,2 );
ReefAngel.Portal( "Nemesis" );
int x,y;
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,54, "PHE:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,54, 100 );
ReefAngel.LCD.DrawOutletBox( 12, 74, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 97, TempRelay );
Here is my sketch:
int x,y;
// pH Expansion
// Relay Expansion
Re: Need help (first time set-up)
No I got it from someone who was tearing down his tank.
Is it a standard RA or a RA+??
You are going to have a hard time trying to fit all that code into the standard RA.
You may need to upgrade to a RA+.
It's just a RA. Should I only use one relay box?
Butting in.
You should upgrade to an RA+. It's well worth the $75. You'll be fighting memory problems forever with the regular RA board. There are just too many new features for it.
So I went ahead and removed one of the relay boxes and was able to download the code to the controller. My problem now is that outlets #2-#4-#6 and #7 do not work. I thought that I might have a bad relay box so I switched it with the other box and I still have the same problem. What am I doing wrong???
Here is the new code:
ReefAngel.FeedingModePorts = Port3Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.MHLights( Port2,10,0,17,0,2 );
ReefAngel.CO2Control( Port3,681,678 );
It was not the same cord, so I switched it with the original cord and it works! I thought you could use any monitor cable? Thanks for all your help.
I want to add my 2 Kessil 360a's to my controler. I'm going to upgrade to the RA+ ,what kind of cable do I need to use the dimming affect?
Once I get these will I be able to use the wizard to program it? I read some of the other posts and it sounds like they had a hard time setting it up.
Yeah, you can use the wizard.
Can you link the thread you are referring to?
