Dimming Module not lighting
paperdesk
Post by paperdesk »
I'm looking for some help getting my dimming module to work with my Evergrow D120 LED's.
Since I haven't learned much about coding yet I used the wizard to set up the module. Perhaps that is where I went wrong? I've been controlling my lights via PWM on the relay box dimming ports and they worked fine. Now I tried using the dimming module and all my lights will do is turn on at the very lowest setting (looks like less than 1%, barely visible). I understood the instructions to say that no jumpers should be used for PWM so I left the jumpers off. When set to 100% I should be able to measure voltage across the dimming module ports right?
Ted
Re: Dimming Module not lighting
Is this a new dimming module?
I've had a few modules that were shipped with the wrong jumper populated.
There is a jumper that is all by itself that is supposed to be off. If it is on, please remove it.
paperdesk
Post by paperdesk »
Yes, it's new, I did notice a jumper like that. I'll take remove it. Thanks.
Correct, please remove it.
paperdesk
Post by paperdesk »
That did it, perfect!
