Dimming Module not lighting
Posted: Tue Dec 09, 2014 5:26 pm
I'm looking for some help getting my dimming module to work with my Evergrow D120 LED's.
Since I haven't learned much about coding yet I used the wizard to set up the module. Perhaps that is where I went wrong? I've been controlling my lights via PWM on the relay box dimming ports and they worked fine. Now I tried using the dimming module and all my lights will do is turn on at the very lowest setting (looks like less than 1%, barely visible). I understood the instructions to say that no jumpers should be used for PWM so I left the jumpers off. When set to 100% I should be able to measure voltage across the dimming module ports right?
Ted
Ted
