Want new main screen, and port control?
Lionfan
Post by Lionfan »
This is my first post. I've been reefing for about 3 years now, and made the purchase of a reef angel just a few days ago. I love learning everything about our reef systems. I have no technology background. At all. I've spent 4 years in the Marine Corps Infantry, and the only thing I know how to do is shoot an M4 and TOW missiles.. Anyways...
I used the wizard to set up the system the way I wanted, but I want to be able to control each port from the controller (mostly for troubleshooting purposes) and also show a graph. When I originally installed the controller with the default settings, it had a graph on the main screen. Now, the only thing the Main Screen shows me is the Temp and Ph. I move the joystick left or right to see different screens, but no graph. I have no idea about the code, and I am doing research constantly on the code to learn.. This is my sketch that the wizard created for me..
[quote]
#include <SoftwareSerial.h>
#include <Globals.h>
#include <RA_Wifi.h>
#include <[color=#CC6600]Wire[/color].h>
#include <[color=#CC6600]OneWire[/color].h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <[color=#006699]LED[/color].h>
#include <RA_TempSensor.h>
#include <[color=#006699]Relay[/color].h>
#include <RA_PWM.h>
#include <[color=#006699]Timer[/color].h>
#include <Memory.h>
#include <RA_Colors.h>
#include <RA_CustomColors.h>
#include <[color=#006699]Salinity[/color].h>
#include <[color=#006699]RF[/color].h>
#include <[color=#006699]IO[/color].h>
#include <[color=#006699]ORP[/color].h>
#include <[color=#006699]AI[/color].h>
#include <[color=#006699]PH[/color].h>
#include <[color=#006699]WaterLevel[/color].h>
#include <[color=#006699]Humidity[/color].h>
#include <[color=#006699]DCPump[/color].h>
#include <[color=#006699]PAR[/color].h>
#include <[color=#CC6600]ReefAngel[/color].h>
[color=#7E7E7E]////// Place global variable code below here[/color]
[color=#7E7E7E]////// Place global variable code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]setup[/b][/color]()
    [color=#7E7E7E]// This must be the first line[/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]Init[/color]();  [color=#7E7E7E]//Initialize controller[/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]AddStandardMenu[/color]();  [color=#7E7E7E]// Add Standard Menu[/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]Use2014Screen[/color]();  [color=#7E7E7E]// Let's use 2014 Screen [/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]AddPHExpansion[/color]();  [color=#7E7E7E]// pH Expansion Module[/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]AddWaterLevelExpansion[/color]();  [color=#7E7E7E]// Water Level Expansion Module[/color]
    [color=#7E7E7E]// Ports toggled in Feeding Mode[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]FeedingModePorts[/color] = [color=#006699]Port1Bit[/color] | [color=#006699]Port7Bit[/color] | [color=#006699]Port8Bit[/color];
    [color=#7E7E7E]// Ports toggled in Water Change Mode[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]WaterChangePorts[/color] = [color=#006699]Port1Bit[/color] | [color=#006699]Port3Bit[/color] | [color=#006699]Port7Bit[/color] | [color=#006699]Port8Bit[/color];
    [color=#7E7E7E]// Ports toggled when Lights On / Off menu entry selected[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]LightsOnPorts[/color] = 0;
    [color=#7E7E7E]// Ports turned off when Overheat temperature exceeded[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]OverheatShutoffPorts[/color] = [color=#006699]Port4Bit[/color] | [color=#006699]Port5Bit[/color];
    [color=#7E7E7E]// Use T1 probe as temperature and overheat functions[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]TempProbe[/color] = [color=#006699]T1_PROBE[/color];
    [color=#CC6600]ReefAngel[/color].[color=#006699]OverheatProbe[/color] = [color=#006699]T1_PROBE[/color];
    [color=#7E7E7E]// Ports that are always on[/color]
    [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port1[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port7[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port8[/color] );
    [color=#7E7E7E]////// Place additional initialization code below here[/color]
    [color=#7E7E7E]////// Place additional initialization code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]loop[/b][/color]()
    [color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]DelayedOn[/color]( [color=#006699]Port2[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardATO[/color]( [color=#006699]Port3[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]DosingPumpRepeat1[/color]( [color=#006699]Port4[/color] );
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardHeater[/color]( [color=#006699]Port5[/color] );
    [color=#7E7E7E]////// Place your custom code below here[/color]
    [color=#7E7E7E]////// Place your custom code above here[/color]
    [color=#7E7E7E]// This should always be the last line[/color]
    [color=#CC6600]ReefAngel[/color].[color=#CC6600]ShowInterface[/color]();
[/quote]
Can anyone help a newbie???
Re: Want new main screen, and port control?
Its not that easy to control individual ports from the controller itself. Its best through the wifi with an android or iphone.
Lionfan
Post by Lionfan »
Ok. I have the wifi module coming in (christmas gift) so Ill cross that bridge when I get there.
