Want new main screen, and port control?
Posted: Thu Dec 11, 2014 5:52 pm
This is my first post. I've been reefing for about 3 years now, and made the purchase of a reef angel just a few days ago. I love learning everything about our reef systems. I have no technology background. At all. I've spent 4 years in the Marine Corps Infantry, and the only thing I know how to do is shoot an M4 and TOW missiles.. Anyways...
I used the wizard to set up the system the way I wanted, but I want to be able to control each port from the controller (mostly for troubleshooting purposes) and also show a graph. When I originally installed the controller with the default settings, it had a graph on the main screen. Now, the only thing the Main Screen shows me is the Temp and Ph. I move the joystick left or right to see different screens, but no graph. I have no idea about the code, and I am doing research constantly on the code to learn.. This is my sketch that the wizard created for me..
Can anyone help a newbie???
[quote]
#include <SoftwareSerial.h>
#include <[color=#CC6600]Wire[/color].h>
#include <[color=#CC6600]OneWire[/color].h>
#include <[color=#006699]LED[/color].h>
#include <[color=#006699]Relay[/color].h>
#include <[color=#006699]Timer[/color].h>
#include <[color=#006699]Salinity[/color].h>
#include <[color=#006699]RF[/color].h>
#include <[color=#006699]IO[/color].h>
#include <[color=#006699]ORP[/color].h>
#include <[color=#006699]AI[/color].h>
#include <[color=#006699]PH[/color].h>
#include <[color=#006699]WaterLevel[/color].h>
#include <[color=#006699]Humidity[/color].h>
#include <[color=#006699]DCPump[/color].h>
#include <[color=#006699]PAR[/color].h>
#include <[color=#CC6600]ReefAngel[/color].h>
[color=#7E7E7E]////// Place global variable code below here[/color]
[color=#7E7E7E]////// Place global variable code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]setup[/b][/color]()
[color=#7E7E7E]// This must be the first line[/color]
[color=#CC6600]ReefAngel[/color].[color=#CC6600]Init[/color](); [color=#7E7E7E]//Initialize controller[/color]
[color=#CC6600]ReefAngel[/color].[color=#CC6600]AddStandardMenu[/color](); [color=#7E7E7E]// Add Standard Menu[/color]
[color=#CC6600]ReefAngel[/color].[color=#CC6600]Use2014Screen[/color](); [color=#7E7E7E]// Let's use 2014 Screen [/color]
[color=#CC6600]ReefAngel[/color].[color=#CC6600]AddPHExpansion[/color](); [color=#7E7E7E]// pH Expansion Module[/color]
[color=#CC6600]ReefAngel[/color].[color=#CC6600]AddWaterLevelExpansion[/color](); [color=#7E7E7E]// Water Level Expansion Module[/color]
[color=#7E7E7E]// Ports toggled in Feeding Mode[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]FeedingModePorts[/color] = [color=#006699]Port1Bit[/color] | [color=#006699]Port7Bit[/color] | [color=#006699]Port8Bit[/color];
[color=#7E7E7E]// Ports toggled in Water Change Mode[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]WaterChangePorts[/color] = [color=#006699]Port1Bit[/color] | [color=#006699]Port3Bit[/color] | [color=#006699]Port7Bit[/color] | [color=#006699]Port8Bit[/color];
[color=#7E7E7E]// Ports toggled when Lights On / Off menu entry selected[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]LightsOnPorts[/color] = 0;
[color=#7E7E7E]// Ports turned off when Overheat temperature exceeded[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]OverheatShutoffPorts[/color] = [color=#006699]Port4Bit[/color] | [color=#006699]Port5Bit[/color];
[color=#7E7E7E]// Use T1 probe as temperature and overheat functions[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]TempProbe[/color] = [color=#006699]T1_PROBE[/color];
[color=#CC6600]ReefAngel[/color].[color=#006699]OverheatProbe[/color] = [color=#006699]T1_PROBE[/color];
[color=#7E7E7E]// Ports that are always on[/color]
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port1[/color] );
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port7[/color] );
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]On[/color]( [color=#006699]Port8[/color] );
[color=#7E7E7E]////// Place additional initialization code below here[/color]
[color=#7E7E7E]////// Place additional initialization code above here[/color]
[color=#CC6600]void[/color] [color=#CC6600][b]loop[/b][/color]()
[color=#CC6600]ReefAngel[/color].[color=#006699]Relay[/color].[color=#CC6600]DelayedOn[/color]( [color=#006699]Port2[/color] );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardATO[/color]( [color=#006699]Port3[/color] );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]DosingPumpRepeat1[/color]( [color=#006699]Port4[/color] );
[color=#CC6600]ReefAngel[/color].[color=#CC6600]StandardHeater[/color]( [color=#006699]Port5[/color] );
[color=#7E7E7E]////// Place your custom code below here[/color]
[color=#7E7E7E]////// Place your custom code above here[/color]
[color=#7E7E7E]// This should always be the last line[/color]
[color=#CC6600]ReefAngel[/color].[color=#CC6600]ShowInterface[/color]();
[/quote]
