Just got a reef angel
Posted: Fri Dec 12, 2014 11:23 pm
by adrenalinejunkie
I just got a used reef angel and not sure how to tell if its a reef angel or reef angel plus. How do I tell witch board I have the reef angel or reef angel w/optiboot or reef angel plus? Also under tools witch programmer should I be using? I think I have picked the wrong settings because ever time I try using the wizard it says that there was an error and cant figure out witch one to use
Re: Just got a reef angel
Posted: Sat Dec 13, 2014 1:08 am
Open it up and look at the writing on the board to be sure.
Posted: Sat May 30, 2015 5:33 am
by adrenalinejunkie
Ok this is the inside of my controller can someone please tell me which controller I have
Posted: Sat May 30, 2015 5:45 am
by adrenalinejunkie
Posted: Sat May 30, 2015 8:11 am
Mine says Reef Angel Plus Main Unit. Sounds like a non-plus. Easy upgrade if you decide to upgrade. You can still get a few things done, it will just be tough to squeeze in.
Posted: Sat Jun 06, 2015 10:05 pm
by adrenalinejunkie
I have set up my controller to run in the past but now I have changed lights and added a few things and now every time I try using the wizard and uploading a new setup I get an error that says not in sync:resp=0x64
Posted: Sun Jun 07, 2015 9:07 am
Make sure you have the correct com port on menu tools->serial port and that you have Reef Angel w/ optiboot on menu tools->board, because your board is the old standard RA board.
Posted: Sun Jun 07, 2015 11:42 am
by adrenalinejunkie
yes they are correct
Posted: Mon Jun 22, 2015 12:18 am
by adrenalinejunkie
Is there anyone anyone willing to call me or that I could call sometime to help me figure out how to use this controller/what I am doing wrong any help would be greatly appreciated
TJ
Posted: Mon Jun 22, 2015 3:19 am
by cosmith71
Are you still unable to upload?
Posted: Mon Jun 22, 2015 3:21 am
by adrenalinejunkie
Yes I still can't upload
Posted: Mon Jun 22, 2015 4:02 am
by cosmith71
Let's start with the basics.
Your RA is connected to either the relay box, or USB power cable connected to a temperature port on the top and the screen is on.
The programming cable is connected to the bottom of the RA with the black wire all the way to the right. There should be an extra space on the left side of the RA.
Go to Control Panel, Devices and Printers. Look for "FT232R USB UART" (with the programming cable plugged in).
If you have multiple serial ports available under Tools in the Arduino program, try a different one.
Posted: Mon Jun 22, 2015 4:43 am
by adrenalinejunkie
Yes that's all correct and I only have one port to choose. I was able to upload the code that I'm currently using by using the wizard when I first set it up but now that I have change lights I wanted to change it and every time I try with the wizard I get an error uploading
Posted: Mon Jun 22, 2015 4:45 am
by adrenalinejunkie
Posted: Mon Jun 22, 2015 7:19 am
Looks like there is something wrong then.
It would be either the board or the cable that is preventing this from working.
If you would like to send both of them back for analysis, send me a PM.
