Is there example code for SIMPLE_MENU that I can use to setup a Custom Menu? I just want to remove some things and add in force cloud. Eventually I'd like to add a force storm menu entry.
Add/change menu items to Simple Menu
- Contact:
Re: Add/change menu items to Simple Menu
http://forum.reefangel.com/viewtopic.php?f=14&t=311StuGotz wrote:Is there example code for SIMPLE_MENU that I can use to setup a Custom Menu? I just want to remove some things and add in force cloud. Eventually I'd like to add a force storm menu entry.
The manual shows you how to mimic the SIMPLE_MENU which sounds like what you are wanting.
StuGotz
Sweet. I was looking http://www.reefangel.com/Download.ashx & http://www.reefangel.com/Support.Creati ... items.ashx for something like that. Exactly what I needed. Thanks!
StuGotz
I got it all added. I had to remove DateTimeSetup from ReefAngel_Features.h, it's custom menu entry and reduce #define CUSTOM_MENU_ENTRIES down to 6 or my sketch was too big. I'll just use the client if I ever have to modify it later.
I'll test the force cloud menu entry tomorrow, the lights are off right now.
Thanks again!
Thanks again!
StuGotz
Force clouds worked! But it definitely messed up my custom main's cloud and thunderstorm line on the LCD Display. I was afraid of that was going to happen.
alexwbush
your main displayed cloud and thunderstorm status?
man... I need to get back into messing with my controller
StuGotz
This should be the part of Roberto's code that displays the info on the custom main. Mine is a little goofed up though... Towards the end of his code
It's great, it tells you what time Clouds will start, and if there's lighting what time that will happen, and the duration of the clouds.
ReefAngel.LCD.Clear(255,0,113,132,121);
ReefAngel.LCD.DrawText(0,255,12,113,"C");
ReefAngel.LCD.DrawText(0,255,18,113,"00:00");
ReefAngel.LCD.DrawText(0,255,52,113,"L");
ReefAngel.LCD.DrawText(0,255,58,113,"00:00");
ReefAngel.LCD.DrawText(0,255,93,113,"DUR");
int x=0;
if ((cloudstart/60)>=10) x=18;
else x=24;
ReefAngel.LCD.DrawText(0,255,x,113,(cloudstart/60));
if ((cloudstart%60)>=10) x=36;
else x=42;
ReefAngel.LCD.DrawText(0,255,x,113,(cloudstart%60));
ReefAngel.LCD.DrawText(0,255,114,113,cloudduration);
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=88;
else x=94;
ReefAngel.LCD.DrawText(0,255,x,113,((cloudstart+(cloudduration/2))/60));
if (((cloudstart+(cloudduration/2))%60)>=10) x=109;
else x=112;
ReefAngel.LCD.DrawText(0,255,x,113,((cloudstart+(cloudduration/2))%60));
